i did not have a failed fuel pump. Nothing happened with my pumps whatsoever the tune f*ed up, thus causing my engine to go lean and put a whole in a piston. This was not Tim's fault as he said he did not tune the car. I had the steeda tune, and something went wrong end of story. Good luck with your car.
Brandon,did you have the voltage checked on the pumps?Check that before you run the car again..I had a few pump setups fail when Steeda was using another manufacturer.They have since switched suppliers and corrected the problem..
I just guessing here,but double check them to be sure....
