LA2 vs LA3
Discussion in '2.3L (N/A & Turbo)' started by 01PonyGT, Mar 24, 2004.
  1. 01PonyGT New Member
    Jul 27, 2003
    Message Count:
    304
    Hey all,
    Just doing some rersearch for my 2.3T swap into my '92 Notch and have pretty much decided to find an '87 or '88 T-Bird TurboCoupe this summer. So here's my question: What exactly is the difference between the LA, LA2, & LA3 computers? I know that LA & LA2 are from 1987 (5spd) and LA3 is 1988 (5spd), but is an LA3 really that much better than an LA2?
    Also, I've read a lot about how to wire these things up and I have to admit I'm confused with all the modifications required and the re-pinning of the harnesses. Wouldn't it be easier to just use the OEM harness from the TurboCoupe and completey replace all of the Mustang wiring??
    Thanks,
    WES
  2. Crovax Type O Danzigative the Dark
    Sep 4, 2000
    Message Count:
    5,460
    88
    I agree!
  3. Xanax New Member
    Mar 13, 2004
    Message Count:
    115
    undefinedLA3
  4. 01PonyGT New Member
    Jul 27, 2003
    Message Count:
    304
    Hey Crovax & Xanax,
    Thanks for the bumps.
  5. Asha'man Founding Member
    Feb 6, 2002
    Message Count:
    1,917
    I think the main thing with the LA3 is that it's reprogrammable if you get an EEC Tuner or similar. Not sure if you'll see a whole lot of difference between the LA series otherwise, although the -3 might have slightly better fuel and timing tables from being from a 5-spd.
    Oh, btw..........I agree.
    Ash
  6. Pro-Hawk New Member
    Dec 5, 2003
    Message Count:
    990
    I really don't know the difference in the EECs but I can give you my opinions on it.
    1) Its the last EEC made for the 2.3T's which I would think would be the most advanced and have les bugs etc.
    2) The PE is the best all out power EEC but the LA3 is realy good but VERY easy to get.
    As for the wiring and rewiring. Just look up GT350R's wiring on a LA3 and you will see its really not to bad. It would be way more work to rewire the hold car than to rewire for the VAM and EEC.
    http://ourworld.cs.com/_ht_a/cobra30197/svo/la3/la3.html?mtbrand=cs_us
    Hawk's Two Cents :)
  7. kiddiccarus New Member
    Dec 24, 2003
    Message Count:
    1,298
    The LA3 is for Large VAM intercooled 2.3T correct?
  8. i4power Founding Member
    Jan 11, 2002
    Message Count:
    1,096
    Yup.
  9. 140cilx Founding Member
    Sep 7, 2001
    Message Count:
    2,385
    Way back when I did a lot of research on this very topic.
    Nobody could confirm anything more than the LA2, LA3, LB2, LB3 all probably have the exact same fuel curves and swapping in any of those in a 5 speed model and running an adjustable boost valve will give you identical performance. Ford has nothing anywhere saying the LA3 has a different fuel curve/more aggressive tables than the '87 version or auto counterparts. The auto versions do run less boost using the stock BCS, but that's to save the tranny, again no biggy if you install an ABV.
    LA3 does accept a tuner though - so if you might go that route down the line I'd find one.
    I wouldn't use the turbocoupe harness, talk about complicating your project. That'd take a LONG TIME compared to modifying the stock harness. Stinger has a specific 91-93 wiring swap page on his website. Just follow it.
  10. Xanax New Member
    Mar 13, 2004
    Message Count:
    115
    I thought the LA3 accepted a tuner tho.Does anyone know about the LA2
    having a more aggressive timming table?
  11. 140cilx Founding Member
    Sep 7, 2001
    Message Count:
    2,385
    read this:
  12. Xanax New Member
    Mar 13, 2004
    Message Count:
    115
    Good looking out!
  13. 01PonyGT New Member
    Jul 27, 2003
    Message Count:
    304
    Thanks for all the replies. I picked up an LA2 on ebay just to have in case I can't get a complete '88 TC. As far as using a tuner....no big deal. Besides, it'll be a miracle if i actually get everything I need and complete the swap this summer so reflashing the computer is the least of my worries. But it's good to know that I could always upgrade to an LA3.
    Thanks again,
    WES
  14. lxturbo New Member
    Mar 26, 2004
    Message Count:
    17
    LA & LB computers
    Guys,
    The LA and LB series computers are about the same as far as fuel curves and such. The LA is five speed material and the LB's are auto. Now before you go yuck, take this into consideration....the LB's are more agressive with the timing and actually give more pep to a five speed car. That is what I am running in mine :flag: :flag: :flag:
Share This Page
