leaf spring change
Discussion in 'Mustang II' started by maverickwolfe, Dec 18, 2007.
  1. maverickwolfe New Member
    Dec 3, 2007
    Message Count:
    21
    I'm swappin' in '74 pintowagon leaf springs on the CobraII but I've hit a bit of a snag.
    the rubber sandwich above and below the leaf spring (isolator/insulator/pad)? what the heck does ford call that and does anybody know the part number for it and/or a place to get 'em? Mine are completely shot and I can't even find a real name for 'em.
    Thanks in advance.
  2. MUSTANG J Member
    Dec 29, 2006
    Message Count:
    355
    They are called Leaf spring isolators. :D
    There main purpose is to cushion the ride (a little) and stop squeaks. I used a jig saw and an old tire to fasion a set for my II. :rolleyes:
  3. welder4956 Member
    Nov 29, 2003
    Message Count:
    179
  4. maverickwolfe New Member
    Dec 3, 2007
    Message Count:
    21
    dangit, wish espo didn't try to hide their axle pads in that goofy blue stripe :)
    I ended up gettin' 'em from MustangsUnlimited for 7.95 a pop, right before readin' the new posts.
    Thanks for the help!
    Got the pieces cleaned and painted today so I should be able to put 'er back together as soon as my 'leaf spring insulators' get here. :D
  5. MustangDuce New Member
    Nov 16, 2006
    Message Count:
    I wish I had known that... I tossed out all the bent rusty brackets and fashioned my own perches and u-bolt plates. Ended up with a decent setup but it looks pretty armature for the amount of work that went into them.
  6. MUSTANG J Member
    Dec 29, 2006
    Message Count:
    355
    Don't feel bad my "rear leaf spring pads" are Bridgestone Potenza's :rlaugh:
  7. feeble New Member
    Jul 31, 2000
    Message Count:
    43
    How did this Pinto wagon spring swap work out? Any problems or regrets?
Share This Page
