B Bronco Bart Member Aug 17, 2022 60 4 8 Huntsville Ontario Canada Mar 30, 2023 #1 Mar 30, 2023 #1 Shut car off in town and won't start. No spark
Rdub6 So while I wait to figure out my rear end issues 5 Year Member Dec 29, 2017 3,698 2,902 153 Long Island, NY Mar 30, 2023 #2 Mar 30, 2023 #2 It’s cranking?
B Bronco Bart Member Aug 17, 2022 60 4 8 Huntsville Ontario Canada Mar 30, 2023 #3 Mar 30, 2023 #3 Rdub6 said: It’s cranking? Click to expand... Yes. Seems to have no spark
AeroCoupe lube between the nut and the face Founding Member Oct 28, 2001 2,591 1,520 153 Claremore, OK Mar 30, 2023 #4 Mar 30, 2023 #4 Did you check at the coil? Reactions: 1 user
M Monkeybutt2000 Mustang Master Aug 11, 2019 1,251 813 123 Lafayette,IN Mar 30, 2023 #5 Mar 30, 2023 #5 Check coil first,if it has spark then it's TFI
B Bronco Bart Member Aug 17, 2022 60 4 8 Huntsville Ontario Canada Mar 30, 2023 #6 Mar 30, 2023 #6 Monkeybutt2000 said: Check coil first,if it has spark then it's TFI Click to expand... I got my passenger to hold on the wires. Coil and plug wires and no shocks
M Monkeybutt2000 Mustang Master Aug 11, 2019 1,251 813 123 Lafayette,IN Mar 31, 2023 #7 Mar 31, 2023 #7 Bronco Bart said: I got my passenger to hold on the wires. Coil and plug wires and no shocks Click to expand... LOL,what?? Reactions: 1 user
AeroCoupe lube between the nut and the face Founding Member Oct 28, 2001 2,591 1,520 153 Claremore, OK Mar 31, 2023 #8 Mar 31, 2023 #8 It holds the wire whilest the motor crankith. Reactions: 2 users
B Bronco Bart Member Aug 17, 2022 60 4 8 Huntsville Ontario Canada Apr 1, 2023 #9 Apr 1, 2023 #9 I swapped out the distributor and it started np. I was stuck in town with the car hoping I could find something easy that might have come apart when I first put the message up. Thanks Bart Reactions: 1 user
