MAC Headers and oil consumption
Discussion in 'SN95 4.6L Mustang Tech' started by Skud, Apr 24, 2006.
  1. Skud New Member
    Sep 10, 2003
    Message Count:
    501
    Saskatchewan
    Hi All,
    I bought a set of the Ceramic coated MAC headers. Shortly after I started to read some threads about people installing these headers and their oil consumption going way up.
    I decided to send an email to MAC's technical support to see what information I could find.
    This is my original email to MAC sent on April 22, 2006.
    I received this responce today (April 24th, 2006)
    Thoughts??
    Thanks!!
    Riley
  2. BurningRubber Active Member
    Dec 6, 2004
    Message Count:
    2,737
    48
    1 quart per 100 miles?
    DAMN! I dont see why "backpressure", or a lack of is going to increase oil consumption like that, that much so.
    So supossidly that letter is saying anyone with longtubes, and an o/r midpipe is gonna consume oil? Hmm...
    Sponsored Ad
  3. mogs01gt Founding Member
    Jul 22, 2002
    Message Count:
    2,926
    Ohio
    It happens on the 4v engines. Its a scavenging issue, not back pressure. I never had that problem. with my MACs.
  4. Skud New Member
    Sep 10, 2003
    Message Count:
    501
    Saskatchewan
    I'm wondering what they have to say about the "sand-like" substance and scored cylinder walls..
    He didn't seem to comment on that. I'm assuming it was a he as there was no name on the email...
    Riley
  5. sgarlic Founding Member
    Apr 22, 2001
    Message Count:
    3,097
    The guy knows what he's trying to say, but just said it rather poorly. I've read several other threads relating to the increased scavenging resulting in oil consumption.
    I haven't heard of a quart per 100 miles, perhaps whoever had also had very high mileage or leaky valve seals or some other issues or something.
    I believe that sand thing/scorred cylinders was from places where mac didn't properly remove burrs from around the rim of the ports, and in the "ventura" or whatever the mac guy called it, pieces get sucked back up in to the combustion chamber somehow. In just about every Mac header thread I've read, at least one person usually mentions to go over them very well with a dremel wire wheel or a wire brush before you install them.
  6. mogs01gt Founding Member
    Jul 22, 2002
    Message Count:
    2,926
    Ohio
    Any aftermarkpart should be looked over with a fine tooth comb. I have never installed any part on my car without inspecting it first. I cleaned my MACs up and they turned out great.
    If you install something on your car without checking to make sure its 110%, its your fault.
  7. COBRA90GT Moderator
    Sep 22, 2001
    Message Count:
    6,836
    86
    HOCKEYTOWN ® , MI
    AFAIK, it is (was) mainly a problem for the 4V engines. People were pointing the blame at MAC's quality control process for leaving excess welding slag inside the headers and the great debate about "too much vacuum" ensued.
    The following thread covers that story (in great detail):
    http://www.corral.net/forums/showthread.php?t=167953
    Bottom line, make sure your headers are clean prior to installing and be wary of MAC longtubes on a 4V engine...
Share This Page
