More project update Pics
Discussion in '94-95 Tech' started by OinkAodeOink, Dec 16, 2003.
  1. OinkAodeOink Founding Member
    Jun 5, 2002
    Message Count:
    3,039
    Daytona bch, Florida
    Getting closer and closer to starting this thing agian. Still need to pick up a bunch of T bolt clampls, some silicone hose, new radiator, FMS throttle body, and ProM univer maf, oh yea, and some brakes, and a tranny cooler.
    Should be running within 2 weeks or so. Gota stop myself from trying to make things look pretty, and concentrate on getting it running. Pretty looks can come later!
    and yea, that innercooler is huge, probably too big, but well see how it does.
    Im re thinking my turbo choice now. Its probably too small, but shouldnt have a problem making 500 to the wheels, although i would love more.
    I'm so used to my 220 h/p car, this things gona feel like a rocket..
    so stoked to get it going agian :D
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
  2. mo_dingo New Member
    Aug 27, 2003
    Message Count:
    3,031
    Tucson, AZ
    What size turbo you running? Looks like a 50/60-something mm turbo, right?
    Did you see blackmagic's numbers with the t66. 500 to the wheels will be very easy. I think he put down 600 w/ 1.5 bar.
    I know what you are going through, making things look pretty. Since it's not your DD, take your time. Everyone says that they will fix things "later, after I get it running".
    The fact of the matter is, if the car runs, I wouldn't touch it. I procrastinate way too much. Getting that "BEAST" would be my #1 goal too. I always say I will fix things later, but never do.
    Good to see everything back together. That intercooler is HUGE!!!! Sucks to see the car dismanteled though. My friend took a picture of me w/ my transmission on the ground. Everytime I see that pic, I remember myself debating whether or not I would actually get the damn thing back in.
    How much boost do you expect from the setup. If you get at least 1 bar, you should see 500 rwtq/hp.
    Scott
  3. 95.0Stang New Member
    Feb 21, 2003
    Message Count:
    544
    Kansas
    I wanna know how you get the engine compartment so clean and free of holes and wires and everything.
  4. WMDPALMER Founding Member
    Feb 28, 2001
    Message Count:
    521
    Lajes AB, Azores
    WOW!!!! That looks so cool! You should buy stock in a tire company from all the rubber you'll be toasting!
  5. VibrantRedGT "STANGNET'S PENGUIN SMACKER"
    Sep 6, 1999
    Message Count:
    14,728
    107
    113
    Boca Raton, Florida
    Mike how did the new struts bolt up?
  6. 1105 I AM the random post master...bow down
    May 3, 2003
    Message Count:
    3,882
    Daytona Bch, FL
    Damn man, thats going to be one monster of a car when you get done :nice: think the stock rearend will be able to handle that power?
  7. Killercanary The car that set the bar.
    Nov 9, 2000
    Message Count:
    5,723
    Altoona, PA
    Damn Mike, that thing looks sick. Please post more details!!! How did that K member bolt up? Were you able to reuse the stock bracing under there?
    You have given me hope that I can do the same to my '90GT.
  8. Killercanary The car that set the bar.
    Nov 9, 2000
    Message Count:
    5,723
    Altoona, PA
    One more thing, do you think your idler pulley on the driver side head will give you problems? That setup looks like you have it attached with only 1 bolt... that would scare me that at high rpm's it would either bend the shaft or put excessive strain in one spot of that aluminum head and maybe "pop" it right out. I'm not knocking the way you did it, I'm just making an observation on something I see might be a problem for you.
  9. Nihilation Founding Member
    Aug 27, 2001
    Message Count:
    1,167
    Manassas, VA
    Howeee Shet Meng...
  10. OinkAodeOink Founding Member
    Jun 5, 2002
    Message Count:
    3,039
    turbo has a 66mm exhuast P wheel, yea i seen Blackmagic's numbers, nice stuff..
    With an innnercooler, i wouldnt be scared to run over 15psi... atleast till it blows up
    All the wiring, fuse box, ect is in the inner fenders, and inside the lower radiator support.
    Tires, yea, smoking em, all through 1st,2nd and some of 3rd is fun stuff. Shouldnt have as bad as a traction problem off the line now, with the suspension work ive done.
    New struts bolted up perfectly. Adjusted the camber by eye, and ride height. Im sure they will need fine tuned, and an alignment, but they went in and on fine.
    Stock rearend shoudl work nicely. Worked great with the Vortech's power, and dont see a reason why the turbo would do it in any sooner. Its been rebuilt, so its all fresh.
    Cars has an auto trans, without a transbrake, so its not very hard on the rear end. Im only worried about the tranny being able to take all the torque.
    K member bolted up perfect, and the engine dropped right in its place like butter. No i wasnt able to retain the K member brace, but i do plan on making custom bracing underneeth. I was surprised how well it fit and lined up, on first try.
    Im going to weld on a side support brace, to bolt the piece to the waterpump. Trust me, il have that thing very stable when im done.. Just put that on last night, and ran out of gas, so il get it welded up soon enough.
    If it doesnt work, il make somthing better, of just buy somthing from march.. Wonder if a Fox a/c delete woudl work better, or even work?
  11. rudeone707 New Member
    May 17, 2003
    Message Count:
    1,849
    Fairfield, Ca
    Everythings coming together pretty fast now, it looks so awesome. Thats a huge intercooler, what made you go that big?
  12. OinkAodeOink Founding Member
    Jun 5, 2002
    Message Count:
    3,039
    becuase it was free, besides the $90 bucks i spent to get the endtanks rewelded..
  13. ChromeYellow94 Founding Member
    Jun 13, 2002
    Message Count:
    937
    Holland Michigan
    Hey oink...
    Looks great :nice:
    Since you're trying to get that pig a little lighter..... Would you be at all interested in a set of Fiberglass doors and Fenders for that pig? I might happen to have a one of three ford prototype Shells with all glass body.....Gonna get some pics up of the fit and everything else. It is a vert
    Just curious.
  14. OinkAodeOink Founding Member
    Jun 5, 2002
    Message Count:
    3,039
    ide love to see some pics of this car..
    sounds interesting but i really need to spend the money on things i have to have.
    Car shouldnt be to heavy anymore.. im hoping it comes in around 3100-3200 or so.
  15. yellow1995Cobra New Member
    Dec 23, 2002
    Message Count:
    2,981
    Massachusetts
    That looks great man :hail2: Its really coming along quickly..
    Are you gonna fab up a bracket for the coil as well? or do you have other plans for it?
  16. OinkAodeOink Founding Member
    Jun 5, 2002
    Message Count:
    3,039
    yea i have an aluminum braket i think might work.. it should go in the same location as stock. Damn MSD coil wire is so short, and that coil plug is short, so il just keep it in the factory location, or nearby
  17. ChromeYellow94 Founding Member
    Jun 13, 2002
    Message Count:
    937
    Holland Michigan
    No prob....Just found out more info....wasn't what I thought it was.....\
    Looks good anyways
  18. 94GTLaserRC Squint as you approach, lest you be blinded by my
    May 7, 2002
    Message Count:
    11,160
    78
    Ernan Says "here it comes... dushbag"
    I just now saw this...I thought that Intercooler was the damn radiator at first :lol:
    RC
    PS...I think LOOKS should come first!
  19. 94Fauxbra New Member
    Feb 24, 2003
    Message Count:
    511
    Boynton Beach,FL
    Some of you guys have way too much Disposable Income...for god sake we are at a state of WAR!!! and there are children starving in Somalia. With the $$$ you spent on your Turbo setup you could have fed a Villiage for an entire year. Can you sense the Jealousy in my Voice. Looks Sick by the way. GOOD LUCK!!!
  20. OinkAodeOink Founding Member
    Jun 5, 2002
    Message Count:
    3,039
    well, ive got almost everything used, at steal prices, or parts have been acuired from trade deals, junk yards, or buddies, and the selling of my vortech( that was bought used also)
    If i had unlimited funds, I would have certanly went with a real turbo ( not one that was cheap, and might work ok)
    a real innercooler ( not one that was free, and is overkill), i would have a real fuel system, more suspesion parts, good tranny, rear end, Fast system, Dart block, Big heads, intake, cam, big injectors, ect.. But im not rich, and dont have those kind of funds, so i do it on a tight budget. Oh yea, and i do all my own interior work, engine work, paint work, polishing, ect.. so that saves alot
Share This Page
