I started up my car this morning to go to class and it wouldn't. The starter turned over fine, I seemed to have full battery, but it wouldn't start the motor. I noticed with the ignition on it said I had absolutely no gas. This confused me, I knew I was low, but not completely empty. However, pressed for time, I took another car with a gas can and put about 3 gallons in my car.
Still didn't start. Fuel meter jumped up, though. It puttered once, and once again later, but never started. All of a sudden all the electrical went dead in the car, but I found it to be a loose negative cable.
I read the codes after class and came up with the following:
P1233 "Manufacturer controlled fuel and air metering"
P0109 "Fuel rail pressure circuit malfunction"
A search here on the forums comes up with
"P0109 MAP/BP Circuit Intermittent "
"P1233 Fuel Pump Driver Module off-line."
I'm going to go look at it again, but does anybody know anything about any of this? I'm sad.
