Predefined "Factory Default" Displays showing OBDII Parameter IDs (PIDs) in an organized fashion.
User defined Displays that can show any supported PID subset in a user chosen format
2 Function Digital (Two large font numeric parameters on your screen)
3 Function Digital (Three medium font numeric parameters on your screen)
4 Function Digital (Four medium font numeric parameters on your screen)
2 Function BAR (Two large font numeric parameters with an updating "Bar" gauge on your screen)
6 Function Digital (Six small font numeric parameters on your screen)
7 Function Digital (Seven small font numeric parameters in a list)
User navigation of displays via the UP and DOWN keys
Real-Time Fuel System Status (on Vehicles that support Fuel System Reporting)
Menu timeouts when no key presses are detected (which returns the user to the previously selected display)
Variable polling schedules for PIDs to reduce CAN bus load
Data Logging capability (on-board) that can be uploaded to a PC via the USB connection
The device is updatable via the USB connection and downloads / software from MSD
LED backlight color is user customizable
User selectable/changeable Alerts
0-60 Times with Speed and RPM recorded
1/4 mile Times/ET (with 60 ft and 1/8 mile splits) with Speed, RPM and Two O2 inputs recorded
0-60, 1/4 mile, and Data Logging data can be uploaded to a PC via the USB conne
Ford Enhanced PID’s
Engine Oil Temp
Trans Fluid Temp
Cylinder Head Temp
Fuel Pressure
Torque Converter Slippage
Pedal Position
I ordered one to see how it works, paid $305 for this toy...........
Ford Enhanced PID’s
Engine Oil Temp
Trans Fluid Temp
Cylinder Head Temp
Fuel Pressure
Pedal Position
I have been around, just not posting much. I saw you were on and ho'ing your toys again so thought I'd give you a shout-out.
