Need help w/ AFM Loadio
GT427
17
AL
Just finished installing some new parts in the gf's 94 GT and need some help getting it back up and running ...
Here's a run down on the setup ... new parts in blue.
Block - Stock 302
Heads - Twisted Wedge
Cam - B 303
Intake - TFS Street
Ignition - MSD 6a | MSD Blaster Coil
Air Induction - AFM LoadIO 90mm MAF | AFM 4" Powerpipe | BBK 75mm TB
Fuel - 24 lb Injectors (flow matched blue tops)
Exhaust - FRPP Shorties | Prochamber | Mac Catback
Rear-end - FRPP 3.73's
Chassis - MM full length Subframes
Suspension - MM CC Plates | Koni Yellow shocks/struts | FRPP B springs
Misc - Pro5.0 Shifter
Got the parts new parts installed and loaded - Light2IV24lb.LIO - and upgraded the EEPROM ... tried to crank the car and it absolutely did not want to start ... it did start after a few tries and staying on the gas, but it wasn't running right (rough) and was putting out a LOT of white smoke. as soon as you let off the gas it dies.
Any help would be appreciated. Planning on giving AFM a call tomorrow.
Thanks
