need help with a 4.6 in a crown vic
Discussion in 'Other Auto Tech' started by tmabarca, Nov 29, 2007.
  1. tmabarca New Member
    Nov 29, 2007
    Message Count:
    the car won't start unless you give it a little gas. then after it it runnung if you let off the gas it dies. you can still drive it but you have to your foot on the gas at all times. thanks for any tips.
  2. timeless2 Vi Veri Veni Versum Vicus Vici
    Apr 22, 2005
    Message Count:
    10,048
    27
    88
    the Shadow Gallery
    When was the last time the air filter, MAF, and IAC were checked or cleaned?
  3. tmabarca New Member
    Nov 29, 2007
    Message Count:
    what is a MAF and IAC? i just put a new air filter and mass air on it about 3 months ago.
  4. Darkwriter77 Resident Ranting Negative Nancy
    Jul 1, 2005
    Message Count:
    3,483
    Apache Junction, AZ
    MAF = Mass Air Flow sensor. It's the thing in the round housing bolted to the back of the airbox. Remove the sensor CAREFULLY and spray some electrical contact cleaner on the two thin little wires (DO NOT use carb cleaner). You can use a Q-tip to scrub off stubborn deposits if you are VERY, VERY careful about it. However, I doubt this is what's causing your problem, which leads us to...
    IAC = Idle Air Control valve. This is on the side of the throttle body at the top of your intake. It's not a major ordeal to remove - just unplug the connector and remove the two bolts - but it's in kind of a pain of a location on the '91 to '95 model 4.6's, because of the different intake elbow and such (points to the front instead of to the side). Remove this thing and hose that sucker out with THROTTLE BODY cleaner - NOT carb cleaner (which can eat up Teflon coatings and such) - and get all of the carbon crap out that you can see. Shake it out and let it dry for awhile before you bolt it back in there. If that doesn't help, you may (or may not) need to invest in a new one, but it's best to try cleaning it first before blowing a wad of cash on a replacement.
    HOWEVER...
    One annoying thing I've always had an issue with on early 4.6's is that stupid friggin' vacuum line running underneath the throttle body elbow. It's this funky reducer of a fitting that goes from something like a 1/2" nipple by the throttle body down to something like 1/4" hard plastic vacuum line that loops around to the PCV valve on the passenger's side. It's a major pain to see, but if you reach back and under there, you can feel it. I wish I had pics available to show you - check out a diagram of the throttle body elbow area in a Chilton manual and you'll see what I mean.
    That vacuum fitting will tend to get all sponge-like and soft as it dry-rots, and it will usually collapse upon itself and/or spring a major vacuum leak. This thing will positively drive you nuts trying to figure out what's causing the problem unless you already know what to look for. I had this problem on my '94 Crown Vic Police Interceptor, my dad had the same on his '92 Crown Vic LX, and I had the same thing again on my '94 Cougar XR7, all with the same 4.6 design. The thing would stall out sometimes right after you stall it, stumble a bit when taking off from a stop, shudder around at cruise on the highway, and sometime trip a Check Engine light.
    Two ways to fix it:
    1. Buy the whole PCV valve "assembly" from Ford for around $40.
    2. Take the old fitting off, go to a parts store, and piece together your own reducer connector with vacuum line and fuel line with a vacuum connector to adapt the two pieces together - might cost you $5 at the most.
    One last thing would be to unbolt the throttle body elbow, itself, swing it up out of the way, and scrape out the built-up carbon crap in the EGR passages of the intake (use a Shop Vac to slurp the pieces out that you dislodge, as you don't want them falling down into the intake). This usually won't cause an idle problem, mostly just a steady-cruise stumble, and it'll keep triggering an "EGR valve malfunction" kind of trouble code. It'll cost you about $5 for a new throttle body elbow-to-manifold gasket, and maybe 30 minutes of your time.
    Lastly, double-check every piece of vacuum line underhood. There's not a whole lot of 'em on the 4.6, but any one of them can make the thing act all kinds of funky until you remedy the problem.
  5. timeless2 Vi Veri Veni Versum Vicus Vici
    Apr 22, 2005
    Message Count:
    10,048
    27
    88
    the Shadow Gallery
    And then Dave shows up.....
  6. Darkwriter77 Resident Ranting Negative Nancy
    Jul 1, 2005
    Message Count:
    3,483
    Apache Junction, AZ
    ...without his Cliff's notes, again. :D
  7. 964.6MGT New Member
    Feb 20, 2008
    Message Count:
    Reynoldsburg
    also, check to make sure your TPS is good, or even connected
  8. Gearbanger 101 That's my secret, Captain. I'm always angry!!!
    Aug 11, 2002
    Message Count:
    11,306
    52
    98
    Ontario, Canada
    Sounds like an IAC issue to me as well.
  9. Shiroelex There's nothing worse than aut
    Aug 24, 2001
    Message Count:
    756
    26
    Westland, MI
    What year is it? Some older ones had a vacuum 'T' near the upper plenum back by the firewall on the passenger side that would collapse over time, and a hole would form in it. It's also on older Tbird and Cougar 4.6s as well, and every one I have come across has been collapsed. It causes all sorts of weird idle problems, and even some lean conditions.
  10. automech New Member
    Mar 7, 2008
    Message Count:
    t sounds to me like you need to have the motor tuned. If it runs rough when it starts and misses, maybe plugs and leads. Does your alternator work properly as it may not be charging enough to the batterie after it is running? Also check the wirings..
Share This Page
