Need help witn Intercooler!
Discussion in 'Saleen' started by fallstar01, Oct 19, 2005.
  1. fallstar01 New Member
    Nov 2, 2004
    Message Count:
    54
    Alright, I don't know if my intercooler is working. I tried running the car to regular engine temp and had my father hit the gas (to go into boost) but I couldn't get the fans to go on. I'm also pretty sure that the water/coolant wasn't circulating.
    What I need to know is:
    What triggers the intercooler pump to circulate the water?
    What triggers the intercooler fans to turn on?
    If you happen to have a similar supercharger setup, how high should the coolant be in the resovoir (above the return line?)
  2. wsbrigham New Member
    Jun 2, 2005
    Message Count:
    327
    I had a similar problem with my fans not turning on (usually about 15-20 seconds after start-up) and my intercooler temp immediately jumped to nearly 200 F on the road. The problem was that I lost/blew the fuse that runs my intercooler fan.
    Hope this helps!
  3. fallstar01 New Member
    Nov 2, 2004
    Message Count:
    54
    I'm all over this. Where was the fuse located? I checked all the ones in my box and I've got no idea which one it would be but none are burned out. I checked the box under the hood as well and they all looked alright. Perhaps I'm missing it altogether or it's actually on a device somewhere? I really appreciate the info.
  4. Mstng2 Founding Member
    Jun 27, 2002
    Message Count:
    789
    18
    Normally the fans should kick on a minute or so after you start the car. Also you can start the car with the resivour cap off and you should be able to see the coolant movement indicating flow. That would tell you the pump is running.
  5. fallstar01 New Member
    Nov 2, 2004
    Message Count:
    54
    No movement. Is there a themostat? I let it get pretty hot. Still hoping someone can tell me which fuse location it might be in?
  6. tfalk Founding Member
    Jan 19, 2001
    Message Count:
    1,803
    38
    "ASSuming" the 01 is the same as the 99, there should be a fuse holder sticking out of a
    hole under the hood in the passenger side fender near the MAF. It leads to the relay box which is
    above the fender well liner on the passenger side. The relay box is basically a timer that waits about
    15-20 seconds after the ignition is turned on, then triggers power to the fans and the
    intercooler pump. Try finding the fuse first. If you can't find it, email me and I can dig up
    the color codes for the wires in the fender well, at least what I wrote down for the 99's.
  7. wsbrigham New Member
    Jun 2, 2005
    Message Count:
    327
    My apologies for the delay in my response.
    Unfortunately, I cannot tell you the location of the fuse because I had my local dealer troubleshoot and replace. Luckily, they didn't charge me a penny to replace the fuse....so I can't give you an idea of what it might cost if you choose to take to the car to a dealer.
  8. fallstar01 New Member
    Nov 2, 2004
    Message Count:
    54
    I'm assuming that the fuse is the little black box right in front of the strut on the passenger side. It's a big metal fuse so I can't visually tell if it's blown. I'll replace it and see what happens. It's pretty difficult to get a good look at the pump or wires coming off of it because of the fender lining. Thanks for the help, I'll be sure to post if it works. The black box I was talking about is pretty visible in this pic.
    [IMG]
  9. tfalk Founding Member
    Jan 19, 2001
    Message Count:
    1,803
    38
    In my car, the fuse is an inline fuseholder and the wiring is in that hole in the fender to the left of the black box you are referring to. I would follow that wire loom that is coming out of the hole, your fuse might be at the end of it that is hiding behind the air tube.
  10. fallstar01 New Member
    Nov 2, 2004
    Message Count:
    54
    I found it. The fuse was blown. It works perfectly now. Thank you very much for your help.
  11. marcus95 New Member
    Jan 27, 2004
    Message Count:
    2,148
    Gotta love the Saleen help desk called the internet.
  12. tfalk Founding Member
    Jan 19, 2001
    Message Count:
    1,803
    38
    Glad to hear it's working again. You should notice a difference in how the car runs, mine pinged a lot and ran like a dog when my intercooler wasn't working.
    Marcus, now you know why my nickname on saleenchat is "Mr. Intercooler" :D :rlaugh:
Share This Page
