New 03 Owner here
Discussion in 'SVT Forum' started by SSinfull, Mar 29, 2004.
  1. SSinfull Founding Member
    Oct 20, 2000
    Message Count:
    202
    First is there anything I can do to get rid of the freaking wheel hop besides swaping out the rear end?
    Secondly, should I go long tubes or mid length headers? Clearance issues?
    How much weight should I shave with Full Exhaust if any?
    And lastly, if I was to do full exhaust, CAI, TB, Diablo, where should I be at the wheels?
    Thanks
  2. Uncle Meat Banned
    Jun 13, 2002
    Message Count:
    3,869
    Yes, but it won't eliminate 100% of the hop. In no specific order you can:
    1. Replace shocks with an adjustable set that offers higher rebound dampening. QA1 or HBH (Horsepower by Herman) are both good choices.
    2. Replace stock IRS bushings with a set of polyurethane bushings.
    3. Get some sticky tires.
    4. Stay away from cold pavement.
    Yes the LT's have clearence issues depending on whether your still at stock ride height. Forget about ever lowering the car if you decide to go with the LT's. Both the LT's and the mid-lengths are expensive and they will not give you a lot of added horsepower or torque unless you are running more than just the basic mods. They are expensive to purchase and expensive to install. Save your money for a Whipple or a KB...
    Well you won't save much over the stock H pipe and cat back system because the OEM parts are stainless steel just like their aftermarket replacements. I did shave a couple pounds going from the OEM manifolds to the JBA shortys.
    I would say anywhere between 415-440 RWHP (Dynojet) depending on the tune. I suggest you forget about the TB for now, you won't get any additional HP or TQ out of it. You also said "Diablo", are you talking about one of their chips or their Predator Performance tune? One is warranty friendly and one isn't... They both can provide the same level of tune in the end though.
    U.M.
  3. Friedchicken Founding Member
    Mar 13, 2002
    Message Count:
    497
    fyi, my x-pipe w/cats and cat back weighed half as much as the stock peices.
Share This Page
