new memeber with question
Discussion in 'Fox 5.0 Mustang Tech' started by eljefe, Jun 9, 2009.
  1. eljefe New Member
    Jun 9, 2009
    Message Count:
    23
    hi everyone i just bought a 1992 mustang gt,
    the previous owner had the engine rebuild about 10,000 miles and installed an Edelbrock 3722 camshaft on it, now the car is running rich, could this be due to the cam?
    other then the cam the engine is stock, any ideas on how to fix this would be really appreciated
    thank you
  2. jrichker StangNet's favorite TOOL
    Mar 10, 2000
    Message Count:
    18,888
    31
    98
    Dublin GA
    How do you know the engine is running rich? Is there a wide band air/fuel gauge in the car? That is just about the only way you can actually tell if a EFI Mustang is rich or lean in street driving.
    Sponsored Ad
  3. eljefe New Member
    Jun 9, 2009
    Message Count:
    23
    it just smells like unburn fuel, thats why i was assuming it was running rich, but ill get a gauge and hook it up just to make sure
  4. LaserSVT Formerly known as *Zap* ImaSammich
    Jun 19, 2007
    Message Count:
    11,533
    321
    133
    Don't matter, had bacon.
    Id check for fuel leaks. Look around the FPR and the fuel rails to the injectors. A worn out gas cap can also do it and as Darkwriter found out the donut gasket around the filler neck wears out as well. :notnice:
  5. strtrcr50 New Member
    Jun 22, 2006
    Message Count:
    2,564
    Previously from Dirty Jerzey exit 7a
    Got cats on the car?
  6. eljefe New Member
    Jun 9, 2009
    Message Count:
    23
    Yes it does have cats
  7. jrichker StangNet's favorite TOOL
    Mar 10, 2000
    Message Count:
    18,888
    31
    98
    Dublin GA
    Dumping The computer diagnostic codes on 86-95 Mustangs
    Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
    Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
    Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
    Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
    Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
    Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
    See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    What to expect:
    You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
    Alternate methods:
    For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
    Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Share This Page
