Noise when going uphill...
Discussion in '94-04 V6 Mustang' started by Rheno, Mar 11, 2004.
  1. Rheno New Member
    Mar 11, 2004
    Message Count:
    Hey guys, kinda have a problem with my 2001 v6 mustang 59000 miles. Everytime when go uphill and press the pedal little bit harder...a kind of rattling noise comes up. Goes away when I put the car in neutral or when I'm going below 2000rpm. I know it's hard to diagnose stuff over the net...but maybe u guys can help. The car doesn't shake or loose performance in any way...the noise sounds similar to putting a paper card in the a fan...
    Thanx in advance...Rheno :spot:
  2. CANTONRACER Founding Member
    Jun 29, 2000
    Message Count:
    888
    Cuyahoga Falls, Akron & Canton, OH
    Is it when you start the car and it is cold?
    What octane you run?
  3. atlblue2000 Founding Member
    Aug 19, 2002
    Message Count:
    1,245
    TN
    Mine does it too...always has. Its probably just bogging the engine and/or tranny down under load @ too low of an rpm. I either just back out of the throttle a little and slowly accelerate up the hill or downshift to pick up the rpms.
  4. Rheno New Member
    Mar 11, 2004
    Message Count:
    that sound...
    no it's also when the engine is not cold anymore...i tried using a higher octane...didn't help. i have auto trans...it just irritates me, that sound...gonna check it out at the dealer probably...by the way is it hard to install a chip?
  5. xneox New Member
    Jan 14, 2004
    Message Count:
    36
    Sounds like classic spark knock to me....if you're trying 93 oct and it still does it maybe you need new plugs?
  6. SpectorV Founding Member
    Sep 3, 2000
    Message Count:
    1,872
    Florence, Alabama
    any time my motor goes below 1200 rpms it shakes and makes awful noises. down shift it :)
Share This Page
