NPI Stangs in here
Discussion in 'SN95 4.6 Talk' started by COramprat, Oct 31, 2008.
  1. COramprat Old guys rule!!!
    Mar 3, 2003
    Message Count:
    5,345
    12
    88
    Sea of Tranquility
    To me it is a misnomer because the only non performance improved aspect of the 96-98 car is the intake manifold.
    Anyway...post up your mods (non headswaped cars only) and any dyno/track numbers you have. I'm interested in seeing who has stayed with the stock heads and their performance numbers. Bone stock to all out modded are welcome.
    See my numbers and mods in sig. Note I have a modest tune since I had over 120K miles after my cam swap and 140K miles when I got my tune.
  2. d98gt Founding Member
    Mar 14, 2002
    Message Count:
    4,243
    42
    88
    SE Texas
    Since my car is undergoing the head swap--I still count for this :rlaugh:
    I had most of the basic bolt ons before a timing chain snapped which resulted in bent valves and shot pistons. I had a thread with pictures and it wasn't pretty. I should had replaced the chains when I installed the cams :(
    I had intentions of staying with NPI heads, however since mine were destroyed and Winters hooked me up with some PIs I really had no option.
    By far the best mod that was done on my car had to be the transmission work (aww yes...a lovely 4r70w here;)). The gears (3.73s) only helped with that and the car actually was capable of decent 60's.
    My current setup, once I finally get it all pieced back of course, is going to be pretty basic but should surprise quite a few people. The car will be a full pi (heads/cams/intake) along with new pistons since I ruined 4 :rlaugh: I believe after all is said and done..this car will be low 13s as I was running a 13.7-13.8 near 100 on the npi heads.
    I will also have to get retuned to make sure im not looking at crazy a/f ratios, though once I get that settled, it's on to Houston Raceway :nice:
  3. Stark77 New Member
    Jun 11, 2008
    Message Count:
    503
    Tallahassee, FL
    Wow - lets see the pictures of the carnage!
  4. d98gt Founding Member
    Mar 14, 2002
    Message Count:
    4,243
    42
    88
    SE Texas
    Being that I have the motor torn apart I will take some extra pictures today of some of the damage. The only pictures that I have aren't the best though are HERE. Don't want to take away from this thread any as I like the idea ;)
    The only "simple" mod that I was missing were longtubes, and that is about to change with this setup :nice:
  5. CobraRed_96_GT Active Member
    May 20, 2006
    Message Count:
    1,644
    36
    UCSD/La Jolla
    13.97@100.5mph with NPI heads 3.73's, full bolt on's outside LT's and a built/stalled auto.
  6. Big Show 96 New Member
    Oct 26, 2008
    Message Count:
    81
    Louisiana
    At 150,000+ miles I installed the following below. The best et was 14.20's at 97-98 mph. No dyno was done. The engine needed head work it started smoking every time it idled, so I went over to the dark side an installed one from an 01 model.:hail2:
    BBK CAI
    BBK 75mm TB
    BBK o/r H-pipe
    Ford racing C springs
    Ford racing Alum Drv shaft
    Steeda under drive pulleys
    PI intake
    3:27 gears 5spd.
    2 1/4 40 series flowmasters.
  7. Winters98GT Founding Member
    Nov 29, 2000
    Message Count:
    5,683
    33
    88
    H Town
    150,000 miles. Stock NPI heads/cams. stock tune, stock 2.73 gears.
    8.82 at 78mph, 1.97 60 ft.
  8. d98gt Founding Member
    Mar 14, 2002
    Message Count:
    4,243
    42
    88
    SE Texas
    and to think that the car that did that now sits with a 5.4 in it :rlaugh:
  9. 98COBRA281 Active Member
    Nov 25, 2007
    Message Count:
    1,417
    38
    Port St. Lucie, Florida
    98 gt 5 speed
    k&n cai
    pi intake
    pi cams
    mac o/r h pipe
    mac cat back
    steeda udp's
    steeda t/a @ 15*
    3.73's
    225.5 rwhp, 270.2 rwtq, running rich as hell!!!
    i wish my new motor was in so i would have some good numbers to post :(
  10. 96SCstang New Member
    Jul 23, 2006
    Message Count:
    231
    novi, MI
    vortech v-1 s-trim with 10# pulley
    snow performance meth kit
    pi cams
    livernois pi intake conversion
    90mm lightning maf
    39# injectors
    anderson powerpipe
    75mm accufab plenum
    stock headers
    bassani catted x-pipe
    magnaflow catback
    prolly missing a few little things but that is major stuff. i am making 375 rwhp and 389 ft lbs of torque on a very very safe tune from livernois.:nice: i am putting a paxton intercooler on this winter for my last performance mod. i see no need to do heads now cause i have just about reached the stock rod potential already. if i ever blow this thing up then i will do a shortblock with ported heads. no track times. its a convertible that weighs damn near 4,000 lbs!!!:(
  11. TGJ New Member
    Mar 31, 2005
    Message Count:
    1,055
    I don't have a NPI Mustang but I do have a 1996 Ford Thunderbird LX Sport that is N/A.
    The mod list:
    - Removed Air Silencer
    - Stock Airbox and Filter
    - 2002 Mustang GT MAF
    - 2004 Mustang GT Intake Tube
    - 75mm BBK TB
    - C&L Plenum
    - FRPP PI Intake
    - Port & Polished PI Portmatched NPI heads
    - Crower Stg 2 PI SC Cams
    - 1996 Teksid 4.6L Bored and sleeved to 3.7" AKA 5.0L Big-Bore
    - Diamond 2V 3.7" Flat top pistons with valve reliefs( 10.5:1 Compression Ratio )
    - Manley Forged Rods
    - Stock Cast 4.6L Crank
    - Cobra Oil Pump
    - TSS Billet Oil pump gears
    - Mark VIII oil pan
    - Kooks mid length ThunderBird headers
    - Magnaflow 3" Spun Cats
    - Magnaflow 3" X-pipe
    - Magnaflow 2.5" Offset/Center out muffers
    - 30 lb/hr FRPP fuel injectors
    - 190 GPH fuel pump
    - 4200 RPM PI Triple Disc TC
    - Built 4R70W auto transmission
    - Dyno-Tech MMX Driveshaft
    - FRPP 99 Cobra Trak-lok differential
    - FRPP 4.30 gears
    - Custom SCT Dyno-tune( Safe 12.5 AFR, 20 Degrees total timing on 91 Octane fuel ).
    348 RWHP - 366 RWTQ -> Not a MISPRINT...
    Note 1: NO CAI, NO UDP's, NO Electric Water Pump, NO Longtubes Headers
    Note 2: Catted Exhaust with safe conservative tune on 91 Octane Fuel
    Note 3: 363 RWHP 370 RWTQ with Power Steeriing Bypass belt and turn downs bolted onto the X-Pipe instead of the mufflers on the same above tune with 91 Octane fuel.
    Note 4: Car had Power Steering Issues before and when it was on the dyno, Power Steering pump has been replaced after car was on the Dyno. That *may* play into the discretion between running the PS and PS Bypass belts...
  12. COramprat Old guys rule!!!
    Mar 3, 2003
    Message Count:
    5,345
    12
    88
    Sea of Tranquility
    Nice numbers TGJ...pretty stout for NA.
  13. 98COBRA281 Active Member
    Nov 25, 2007
    Message Count:
    1,417
    38
    anybody else!?!?!, i know theres alot more npi's here:D......
  14. LI98GTStang Founding Member
    Jun 22, 2000
    Message Count:
    1,718
    36
    L.I., NY
    My mods are PI cams PI intake, Bassani Catted X w/bassani muffs, 3.90s, Steeda pulleys, on stock (untouched) NPI heads.
    Dyno-wise, I made 229rwhp prior to the 70mm TB and TF upper intake and am still on stock tune with stock timing (no T/A either). Best 1/4 mile time is 13.72 with 1.9 60' with DRs.
  15. mustangman9812 Active Member
    Jan 14, 2004
    Message Count:
    613
    26
    Mars Hill, North Carolina
  16. 98COBRA281 Active Member
    Nov 25, 2007
    Message Count:
    1,417
    38
  17. bhuff30 Founding Member
    Dec 11, 2001
    Message Count:
    5,796
    78
    Lenexa KS
    I'm on the closer to stock side with 150k miles as well. Only mod is an off-road H pipe. Everything else was stock... paper filter, street tires, stock shifter. Quarter mile times are in my sig.
  18. justinschmidt1 Member
    Jun 16, 2005
    Message Count:
    353
    My car has pretty much full bolt ons, pi intake and a procharger at 10 psi with 115k on it
    Ran 12.8 at 113 on street tires with a turd trans.
    Getting my built trans in right now with a 3600-3800 converter so im looking forward to low 12s if not high 11s
    Im gonna need some new tires of course
  19. COramprat Old guys rule!!!
    Mar 3, 2003
    Message Count:
    5,345
    12
    88
    Sea of Tranquility
    Pretty nice times with your mods. I need to catch up.
  20. Winters98GT Founding Member
    Nov 29, 2000
    Message Count:
    5,683
    33
    88
    H Town
    LI and Comp, what were your 2 1/8 mile times and trap speeds? I'm curious were I would have been. My 60 ft was only a 1.97-1.99 on my runs, I was launching off the limiter but did not have enough gear to get the car in the 1.8 to low 1.9 range.
Share This Page
