P1443.. What does it mean?
Discussion in 'SN95 4.6L Mustang' started by 4.6vertGT, Mar 17, 2007.
  1. 4.6vertGT New Member
    May 18, 2005
    Message Count:
    76
    Since I purchased my GT, the check engine light has been coming on and off. It usually only stays on for a few minutes every 2 weeks. I went to AutoZone while the CEL was on, and they gave me this code.. P1443. It says on the reciept they gave me, "Evaporative emission control system control valve." First of all, is this that bad? Second, where is this so called valve? If it has something to do with the midpipe, I'm just gonna fix it by an o/r pipe with some MIL eliminators. So, help me please!
  2. TripleBlk Member
    Nov 13, 2002
    Message Count:
    287
    I had that code once or twice a long time ago. It was caused by the gas cap(loose). I just reset the code and never saw the code again. HTH
  3. 4.6vertGT New Member
    May 18, 2005
    Message Count:
    76
    yeah, they reset the code for me but i hope it doesnt come back. I noticed that my gas cap doesnt feel like it locks in too tight, but it still seems tight enough to not cause a problem....
  4. COramprat Old guys rule!!!
    Mar 3, 2003
    Message Count:
    5,296
    88
    It could be tight but not sealing properly...
    From another thread:
  5. Mike97gt it doe snot
    Jan 26, 1999
    Message Count:
    12,475
    76
    this code will not be set by the gas cap being loose.. that code would be for a gross evap leak, this is a electrical fault most likely a bad evap canister purge valve. take a look at the electrical connector on it and make sure it's ok.
  6. CanadaStang New Member
    Sep 7, 2003
    Message Count:
    2,103
    What he said ^^
  7. 4.6vertGT New Member
    May 18, 2005
    Message Count:
    76
    thanks for the help guys, i checked the connectors and i guess ill see if it ever comes back...
  8. COramprat Old guys rule!!!
    Mar 3, 2003
    Message Count:
    5,296
    88
    I get the same code on occasion. Throws 2 in succession. Just bee too busy with other items with the car to fool with it yet.
  9. RandyStinchcomb New Member
    May 25, 2005
    Message Count:
    1,172
    what year is the car?
    if its pre 1998, I'd suspect the canister purge solenoid and the thermistor, very common problems on pre 1998's wth 60k or more
  10. 4.6vertGT New Member
    May 18, 2005
    Message Count:
    76
    wow, thanks. its a '96. good call. but would i just go to the dealership and ask for those parts, or pay a bunch of money for them to hopefully tell me its those parts?
  11. RandyStinchcomb New Member
    May 25, 2005
    Message Count:
    1,172
    its a common problem.
    parts need are a E6ZZ-9C915-A canister purge solenoid @$46.30* and the thermistor, part # F57Z-14A606-BA @$18.00*
    *wholesale, thru us. both are dealer ONLY parts
  12. 4.6vertGT New Member
    May 18, 2005
    Message Count:
    76
    thanks alot randy. and by the way, are these parts that are easy to install?
  13. RandyStinchcomb New Member
    May 25, 2005
    Message Count:
    1,172
    very easy, both parts are on the same vacuum line comming off the plenum on the rightside of the engine, near the firewall. and if you have trouble getting them, we have plenty in stock
  14. KillaGT New Member
    Jul 10, 2007
    Message Count:
    507
    SORRY TO BRING BACK THE OLD THREAT.
    RandyStinchcomb , do you still carrry those 2 part ? I really need it now. thanks
  15. BlackGT4.6 New Member
    Jun 15, 2005
    Message Count:
    103
    another possibility is a vacuum leak. or my maf being dirty for some reason caused this code :shrug:
  16. SaleenGT2001 New Member
    Jul 19, 2005
    Message Count:
    2,925
    it will be easier to contact him over on modular depot. just look under ford factory parts
  17. RandyStinchcomb New Member
    May 25, 2005
    Message Count:
    1,172
    always:D
  18. KillaGT New Member
    Jul 10, 2007
    Message Count:
    507
    hey hey, how much for 2 part + s/h to 39110 ? thanks
  19. RandyStinchcomb New Member
    May 25, 2005
    Message Count:
    1,172
    @$75.00 shipped
  20. KillaGT New Member
    Jul 10, 2007
    Message Count:
    507
    Deal, I look at your site, and search for the part. none come up ? how do I pay you ?
Share This Page
