I ordered mine from them and I have a 90 GT with battery on the drivers side. I ordered the 160A and long premium wire. The long wire goes along with the harness from the alternator, out front around the radiator then under the battery tray to the starter solenoid. All needed parts came with it and it had the alternator hole threaded, everything fit perfectly. I did use the original 10ga wire but removed one at the splice to make room for more connections. The original wiring used two 10ga to the alternator connector because the connector pins couldn't handle the full current, then they are joined to one 10ga wire (this wire has to be used in addition to the 4ga wire for a neat easy installation).
Don
