points conversion
Discussion in 'Classic Talk' started by Shane54, May 4, 2007.
  1. Shane54 New Member
    Sep 4, 2001
    Message Count:
    39
    Las Vegas
    Want to switch to pointless system whats the best one to use?
  2. 68stang351 Founding Member
    May 17, 2002
    Message Count:
    1,870
    38
    Savoy TX
    I've used Pertronix Ignitor in the past and it worked very well. The installation was also very simple.
  3. Blu-Steel Member
    Dec 29, 2006
    Message Count:
    92
    Waynesville, MO
    Ditto on the Pertronix. It was easy to install and works very well.
  4. zookeeper Founding Member
    Aug 25, 2001
    Message Count:
    3,087
    56
    Northern California
    One more for the Pertronix. I have the Pertronix 2 and I swear, if you can find the sharp end of a screwdriver, you can install it in under an hour. The hardest part is finding the end of the pink resistor wire to connect it to, and that took a whopping 10 minutes.
  5. rbohm Founding Member
    Apr 13, 2002
    Message Count:
    4,770
    68
    tucson,az/luray,va
    the pertronix is good, as is the crane xr-700(i have that on my 64 falcon), but i started with a duraspark distributor and hooked it to a chrysler ignition box and added an msd blaster 3 coil for my 66 falcon. it works great.
  6. 351carlo New Member
    Mar 9, 2004
    Message Count:
    270
    Philadelphia
    Just to convert, I love my Pertronix Ignitor II setup. Problem is it relies on the stock distributor, so make sure it isn't worn and has the proper curve/springs.
    However for a race application, or anything high performance I wouldn't even think about running a setup less than what I have now. Mallory Comp 32 S/S billet distributor with an MSD Digital 6 Plus box and a matching big Mallory coil. I get spark to 7k without a problem, and the car keeps pulling.
  7. bnickel Founding Member
    Aug 21, 2002
    Message Count:
    5,642
    76
    lubbock, texas
    i have a mallory unilite conversion in my stock dizzy, been there for almost 20 years and no problems other than a couple of bad modules due to a manufacturing defect back in the early 90's. that problem has since been corrected and they don't have a problem with the modules any more. the one that's ine the car currently has been there for over 15 years now.
    the accel conversion kit is teh exact same kit as the mallory but much less expensive because of the accel name rather mallory, they are both owned by mr. gasket and every single component of teh kit is identical as far as i can tell.
    the pertronix is good as well.
  8. fox-gt Member
    Feb 28, 2004
    Message Count:
    191
    TN
    Pertronix + 1
  9. splinterddt Founding Member
    Sep 5, 2000
    Message Count:
    198
    Florence, CO, U.S.A.
    I've had the same Pertronix unit through 2 engines and several years without any problems (actually I forgot to hook up the ground wire when going from the small-block to the big-block, but after 5 min I found the mistake). If you're converting from points, it's the easiest and cheepest. There's always bidder and better, it just depends what you're looking for and how much you want to spend.
  10. j69302 Active Member
    Jan 31, 2006
    Message Count:
    279
    26
    Does anyone know the gap for the control module to the magnetic rotor? I looked on pertronix sight for instructions but in the instructions they didnt have it listed. I need to check mine and dont know what it should be. This is the original Pertonix I setup.
  11. Az Pete Member
    Mar 31, 2005
    Message Count:
    567
    18
    Panama City, Fl.
    I just use the plastic gauge they included. Couldn't tell you the gap though. I did make sure I kept that plastic though. I have no way to measure it right now. sorry
Share This Page
