pro kit installed....not much drop
Discussion in 'SN95 4.6 Talk' started by streethorse, Mar 19, 2007.
  1. streethorse Active Member
    Oct 8, 2005
    Message Count:
    1,000
    38
    Had the eibach pro kit installed by dallas mustang last friday on my 04 GT.
    They did a fine job it seems but the drop is not what I wanted.
    I took very careful measurements in different places so as to know exactly what
    drop I got. Anyway I got 3 quarter inch drop in the back and only 1 quarter inch
    drop up front. Looks good but the front fender gap looks a tiny bit bigger than the back. I would be happy if the front drop was the same as the back.
    I mean Eibach advertises a 1 to 1.5 inch drop all the way around.
    I used the stock issolaters on all 4 springs. Whats up with this? will it drop more?
    I called Eibach 2 times and they hung up on me once they knew I was not happy.:mad:
  2. RedHorse04 New Member
    Sep 30, 2006
    Message Count:
    10
    It should settle to be about an inch all the way around. It took my car about a week I think to settle all the way. I like the prokit it lowereed it just enough for me.
  3. RoadconeTuning New Member
    Apr 4, 2006
    Message Count:
    461
    you got hosed... mine dropped about 1 inch in front instantly... and the back sits perfect....
    This is abotu 10 minutes after it came off the jack stands.
    [IMG]
  4. SamMan New Member
    Aug 20, 2005
    Message Count:
    150
    Ive got the same springs. They will settle after a couple weeks just give it a little time.
  5. merc123 Active Member
    Jan 27, 2003
    Message Count:
    1,958
    36
    Give them time. My front dropped a little bit over time.
  6. mjkids New Member
    Oct 28, 2006
    Message Count:
    i have the pro kit on my that sounds about right it will sit down a little over time but what i did was change my ball joints and the front gap goes down to sit like the back
  7. flyboy86 New Member
    Dec 5, 2006
    Message Count:
    114
    I did the pro-kit also, and mine dropped more after a while. Also, if you want more drop, you could take the isolaters out. I did that, and i'm very happy with it.
Share This Page
