I have a 66 Coupe with a 289. The engine appears to be correct for the car; I even have the aluminum date code tag, which is attached to the intake manifold. It give a January 1966 build date.
Problem is the engine has been bored .040" over already and may or may not be able to run well with only a hone. I should find out more on that tomorrow.
The heads most likely need machining also.
Problem is I want to get the HP up to around 300 and with the stock heads, intake, exhaust manifolds and the 2 barrel carb that is not likely.
If the block can be used I still need to install aftermarket heads, intake, and exhaust as well as other additional parts.
I wonder if this is a foolish thing to do, since the engine matches this car?
It is a couple, needs paint and seat covers etc. but is not a beat up Mustang. Rust is very limited.
There is a 302 that can be had, rebuilt and fitted with the top parts to get me to where I want to be. As much as I would like to keep the 289 in storage I have no room to do so.
What do think, what did you or others that you know do?
tia
sparx
tia
sparx
