question about aluminum ds
Discussion in '2005 - 2009 Specific Tech' started by blackjack21, Aug 12, 2008.
  1. blackjack21 New Member
    Aug 11, 2008
    Message Count:
    34
    what do you guys/gals recommend for an aluminum ds......site,name?
    if you are at stock height, do you have to change the pinion angle?
  2. Grabber07GT New Member
    Nov 17, 2006
    Message Count:
    Spydershafts are suggested a lot. You can read more here:
    Spydershaft
  3. chad9350 New Member
    Jan 13, 2007
    Message Count:
    253
    Spydershaft; had mine for over a year now... problem free:nice:
  4. Hoboattacker New Member
    Sep 7, 2005
    Message Count:
    550
    Spydershaft, Coast driveshafts, Driveshaft Shop, The Axle Exchange, etc...there are quite a few. Just gotta do good research.
  5. blacksheep06 New Member
    Feb 1, 2006
    Message Count:
    291
    I've had the spydershaft for almost a year with no problems. It comes with a pinioin flange.
  6. white07gt-cs New Member
    Dec 21, 2006
    Message Count:
    103
    Is anyone using a spydershaft with a FI engine? I've been told to stay away from aluminum unless it's at least 4" for supercharged cars. I've read that 4" shafts can cause clearance issues with lowered cars. I was thinking about going to an aluminum driveshaft but my future plans for FI made me decide to hold off.
    Does anyone here have the real scoop on these issues?
  7. BJ1000RR New Member
    May 2, 2006
    Message Count:
    60
    I have the Coast Driveline shaft, & it's rated to 500 hp. they also sell one rated for 600 hp, so if you plan to build less than 600 hp they have a shaft for you.
  8. kooldawg6 mine works really well and can take a fair amount
    Aug 31, 2006
    Message Count:
    1,718
    The Spydershaft has been tested repeatedly at the track with slicks and 500 RWHP.
  9. Riggs Member
    Mar 31, 2005
    Message Count:
    145
    Shaftmasters is good too and very affordable.
  10. StonePony New Member
    Jan 10, 2006
    Message Count:
    218
    Powerhouse 4" aluminum shaft.
    Bolted in in 45 minutes. If you are not lowered there is no need to change pinion angle. I tested mine to 170 MPH without vibration and have run it for two years at the dragstrip without issue.
  11. Emay New Member
    Oct 4, 2006
    Message Count:
    233
    Runnin the spydershaft for a year now, with the car lowered on prokit springs, a hurst shifter, bmr adjustable UCA, and the bmr front driveshaft loop. I have zero clearance issues. Ran the car for months without the UCA and it was fine that way as well..
  12. white07gt-cs New Member
    Dec 21, 2006
    Message Count:
    103
    Thanks for all the informed feedback. It sounds like my concerns were not well founded.
  13. blackjack21 New Member
    Aug 11, 2008
    Message Count:
    34
    is it necessary to have the safety loops????? just my dd car
  14. JPAC New Member
    Jun 17, 2008
    Message Count:
    I run a coast ds. I have the prokit springs and have had clearance issues only at the track. I was running ET street slicks and launching at 5000. Cured by adding a little more neg pinion angle and massaging the tunnel with a hammer and grinder.
  15. JPAC New Member
    Jun 17, 2008
    Message Count:
    Oh, and it is a good idea to throw a loop on while you have it apart. Just in case you ever hit the strip with slicks. I put a BMR unit on mine for $99.
  16. anticubicle New Member
    Jul 31, 2007
    Message Count:
    268
    What kind of gains are people seeing with the Spydershaft?
  17. mhanksii New Member
    Jan 3, 2006
    Message Count:
    331
    Is there more or less gain with a F/I setup? I was thinking about a driveshaft but not sure if that would be better than some gears or maybe both. Any input/adivce?
  18. mhanksii New Member
    Jan 3, 2006
    Message Count:
    331
    No one?
  19. BJ1000RR New Member
    May 2, 2006
    Message Count:
    60
    You will see more gains with a F/I setup, but maybe 2 tenths on an otherwise stock car.
    I personally like the stock 355 gear, because you dont have to shift out of third in the 1/4.
  20. ranger04 New Member
    Jul 28, 2007
    Message Count:
    246
    Not shifting out of 3rd isn't really a good thing. Gears are a torque multiplier, they get you to the sweet spot faster. Only using 3 gears seems like a lazy sorta run and your not getting the full potential of your engine. If your pounding 6,200 rpm's through 4 gears in the 1/4, your humping. I maybe looking at this all wrong, but with my 4:30's, it screams, the power stays on tap. It pulls hard through 4 gears. It's a lot quicker than it was with the 3:31's. Like I say, I might be looking at this all wrong, but with 3:55's your scrubing off some speed it seems to me.
Share This Page
