question about stage II and tuner kit
Discussion in '94-04 V6 Mustang' started by striped, Dec 15, 2003.
  1. striped Founding Member
    Feb 18, 2002
    Message Count:
    251
    on rmpoutlet.com they have somthing called the Stage II HO kit....heres the link to the kits. http://rpmoutlet.com/musv6ati.htm ..... is this basicly the tuner kit with a smaller pully. Im asking this because its priced more then the tuner kit and has every thing you need for the kit, unlike the tuner kit. It also says it can run 11psi.thanks
    chris
  2. stlboarder Founding Member
    Jul 1, 2002
    Message Count:
    224
    wait... I don't understand what your asking.
  3. DoubleODork Founding Member
    May 11, 2001
    Message Count:
    73
    The tuner kit dosent come with a FMU, fuel pump, computer chip, ect. The other, more expensive kit, has all that.
  4. striped Founding Member
    Feb 18, 2002
    Message Count:
    251
    k, there is a kit called the HO stage II kit listed right above tuner kit. I was asking if the stage II HO kit was basically the tuner kit with every thing needed to install it.....
    chris
  5. ryanrule impotent
    Feb 11, 2002
    Message Count:
    1,437
    none of those has everything u need, u still want a fuel pump and injectors at least
  6. striped Founding Member
    Feb 18, 2002
    Message Count:
    251
    I just called them and they said it comes with every thing besides the injectors. Do u guys think i should just get the tuner kit and buy every thing from fordchip.com or use there FMU and custum chip and buy my injectors from turbo ford. Im going to order when i get my info right so i need help asap.thanks
    chris
Share This Page
