Rattling Hurst, Need input.
Discussion in '2005 - 2009 Specific Tech' started by bynumj, Feb 19, 2008.
  1. bynumj New Member
    May 21, 2007
    Message Count:
    77
    I installed a Hurst shifter in September. I did not have any problems with it after I installed it, but now that the cold weather has passed for the most part I took my car out for a spin and the shifter makes a rattling sound now. I checked all the bolts under the car and they are tight. The shifter does have approx. ½ inch play in it moving up and down. When I have it in gear and take my hand of the shifter and accelerate, it rattles like crazy. If I put my hand back on the shifter is quiets back down. Has anyone experienced this? Any ideas? Thank you for your input.
    (FYI, this is requesting info about this problem and not requesting info on other shifters or why you don’t like the Hurst and why I should buy something different).
  2. Hoboattacker New Member
    Sep 7, 2005
    Message Count:
    550
    My car is doing the same exact thing. I have no idea if it is loose bolts or not (haven't been under the car yet) but I am getting sick of it. It's been going on for about 3-4 months now and I'm just about to rip the Hurts out and buy a used Steeda Tri-Ax instead.
  3. bronco78 Member
    Jul 10, 2005
    Message Count:
    89
    Having just installed a Hurst, the design is fresh in my memory. If the shifter lever is moving up and down, then the spherical bearing used as a pivot point must have an issue. there is a snap ring the keeps it in place,, perhaps it has popped pout?
    Should be obvious if you remove the shifter and have a look. PITA for sure., But it's not likely to fix it self.. So take the 20 minutes required to pull it out and have a look, or just buy a new shifter, and skip having to deal with it. Either way should work.
  4. bronco78 Member
    Jul 10, 2005
    Message Count:
    89
    double post
  5. PoopDawg Autozone Junkie
    Jun 21, 2002
    Message Count:
    1,408
    36
    Mine makes the same rattle around 3500 RPM when cold. But it goes away when it warms up. Doesn't bother me. Everything is tight and installed correctly.
  6. bynumj New Member
    May 21, 2007
    Message Count:
    77
    The snap ring is in place. The movement up and down looks to be independent of the bearing itself.
  7. 05xgt New Member
    Jan 18, 2007
    Message Count:
    85
    Try re-tighening the two torx head bolts that bolt the shifter handle to the base, also use Loc-tite on the threads. I had the same problem until I did this. No more problem.
  8. RBonite New Member
    Jun 9, 2006
    Message Count:
    9
    Same here. Loc-tite made the difference.
  9. LV51FER New Member
    Oct 25, 2005
    Message Count:
    319
    If the bolts go into the threaded part on the base, you can sometimes have the bolts done up tight but still with a gap between the face of the base and the shifter stalk. Unscrew, place faces flat together and screw together.
  10. Emay New Member
    Oct 4, 2006
    Message Count:
    233
    I've replaced 2 of the Hurst shifters over the last 6 months for this same exact issue. A member here (Dennis) had me replace one mid 07 as well.
    That half inch of up and down play is not supposed to be there, as mentioned the sperical bearing itself has created space and rattles. Dennis' started doing it within a weekends worth of use. Hopefully he will chime in.
    Dennis arranged his replacement, not sure if his was covered by the location he ordered from or by Hurst direct. I know for a fact the other two were replaced under a warranty via hurst and no problems since..
  11. walter Founding Member
    Aug 13, 1998
    Message Count:
    1,068
    46
    I believe Steeda also makes an insulator piece that you slide between the handle and the base attachment point which is supposed to cut down on vibrations that get transmitted through the shifter.
    Mine rattles a bit after 4K RPM at full throttle.
  12. bynumj New Member
    May 21, 2007
    Message Count:
    77
    Finally some answers
    I talked to someone at Hurst (B&M Automotive Products) and they said that it is possibly a faulty bearing assembly. They stated that this was a problem with early production shifters and assured me the issue has been fixed in the new shifters. They said that they would send me a new shifter if I send them the old one; I am waiting to find out what do. I am going to try and arrange for them to send me the shifter first so that I only have to get under the car and make the change once. I will keep you all up to date.
  13. 4U2TAME New Member
    Feb 29, 2008
    Message Count:
    Anything new happen on this?
  14. bynumj New Member
    May 21, 2007
    Message Count:
    77
    Well it has been awhile, I got a replacement shifter from Hurst. The new shifter does not have the up and down play in it. However, there is still a slight rattle in it. From everything that I have read, I think this is something that has no fix. I am continuing my quest to rid the shifter of the rattle. Hell, if I can find an engineered solution for cheap, I a make a killing on it. It appears that every Hurst shifter made for theses cars and the corvettes have this rattling problem. I think that there is a slight gap in the bearing design or loose tolerances. I used some oil on the bearing and it stopped rattling for an hour. When the weather gets better, I am going to get it out and come up with a bulletproof fix to this problem. I will be the hero of all Hurst shifter owners:hail2:
  15. klaw Member
    Oct 11, 2007
    Message Count:
    354
    I have a Hurst and it developed a rattle. It turned out to be the two torx head screws on the handle. Loctite did the trick. No rattle at all now.
  16. groovyguru New Member
    Dec 15, 2008
    Message Count:
    Rattling Hurst - fixed it this way
    I had the same problem and it drove me nuts. One night I pulled the leather boot up and squeezed a bunch of lithium grease into the shifter, then put the boot back on. That was a year ago. It has not made a sound since.
  17. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    Dynamat and Dynapad around the shifter opening and Dynamat on the E-Brake handle, like MGW does, will help cure a lot of noise issues.
Share This Page
