Rear leaf spring bushings
Discussion in 'Mustang II Parts' started by 69gmachine, Aug 2, 2006.
Thread Status:
  1. Does anyone know where I can get replacement rear leaf spring bushings for the Mustang II? I would prefer poly if anyone makes them for this application, but I'll take what I can get.
    Thanks!
  2. I looked all over but just ended up having to make my own! It did not turn out too bad, I made it out of an industrial sonic/concussion free walking mat. It was designed for years of tough wear and man lb per square inch. But yet it was still soft enough to help dampen vibrations!
    I hope that helps,
    Chad
  3. Thanks for the reply. Wasn't the answer I was hoping for, but I certainly have to admire your ingenuity and resourcefulness.
  4. Poly shackle bushings for $3.00... Perfect! Thanks for the info CobraII
  5. Dohh I was talking about the rubber that goes between the spring and the shock mounts :)
  6. That's ok they have those too.
    Tim
  7. do you mean the rubber part that sandwichs the leaf springs at the piont where the rear end bolts onto the springs? if they do i could'nt find it, do you know the part number because i'm in need of them too.
  8. Look at the very bottom of the "early mustang" section.
    Mustang
    YEARS --> 65-66 67 68-69 70-73 74-78 <-- YEARS
    Front End Kits Front End Kits
    w/Rubber Bushings 8 CYL $250 $320.00 $245.00 $240.00 $210.00 w/Rubber Bushings
    w/Poly Bushings 8 CYL $290 $350.00 $280.00 $275.00 $225.00 w/Poly Bushings
    Coil Springs Coil Springs
    Front (Pair) $65-$85 $65-$80 $65-$80 $65-$80 $60-$70 Front (Pair)
    Poly Bushing Kits Poly Bushing Kits
    Front Control Arm Bushings (Set) $11-$15 $11.00 $11.00 $11.00 $35.00 Front Control Arm Bushings (Set)
    Spring Accessories Spring Accessories
    Shackles Shackles
    w/OEM Bushings (ea) $15.00 $15.00 $15.00 $15.00 $15.00 w/OEM Bushings (ea)
    w/Poly Bushings (ea) $19.00 $19.00 $19.00 $19.00 w/Poly Bushings (ea)
    Spring Bolts (ea) $3.00 $3.00 $3.00 $3.00 $3.00 Spring Bolts (ea)
    Spring Bushings Spring Bushings
    OEM - Fixed End (ea) $11.00 $11.00 $11.00 $11.00 $11.00 OEM - Fixed End (ea)
    OEM - Shackle End/Frame (ea) $2.00 $2.00 $2.00 $2.00 $1.50 OEM - Shackle End/Frame (ea)
    OEM - Shackle End/Spring (ea) $2.00 $2.00 $2.00 $2.00 $3.50 OEM - Shackle End/Spring (ea)
    Poly - Fixed End (ea) $11.00 $11.00 $11.00 $11.00 $11.00 Poly - Fixed End (ea)
    Poly - Shackle End/Frame (ea) $3.00 $3.00 $3.00 $3.00 $3.00 Poly - Shackle End/Frame (ea)
    Poly - Shackle End/Spring (ea) $3.00 $3.00 $3.00 $3.00 Poly - Shackle End/Spring (ea)
    U-bolts (ea) $4.00 $4.00 $4.00 $4.00 $4.00 U-bolts (ea)
    1974-78 REAR AXLE PADS $6 EA
    Tim
Thread Status:
