rear seat
No pics... sorry
1. Remove the lower seat cushion by pushing in the lock tabs directly under the front of seat.
2. fold down the rear seats. you will see three 10mm bolts that hold on the upper trim piece. remove the three bolts and the trim piece.
3. remove the two bottom 10mm bolts on the bottom of the seat back frame (you may need to take out the pins holding down the trunk mat). remove the top two 10mm bolts on the top of the seat back frame. then romve the enire back seat from the car.
