RearEnd Gears
Discussion in 'SVT Forum' started by BlownSnake04, Dec 31, 2004.
  1. BlownSnake04 New Member
    Nov 25, 2004
    Message Count:
    Millstone, New Jersey
    Hey I'm looking to put a new set of rear end gears on my 04 Cobra. I am interested in 4.10! Has anyone installed these on their car..if so how'd it work out? I am interested to hear from Cobra owners with different ratios also..THANKS!
  2. Uncle Meat Banned
    Jun 13, 2002
    Message Count:
    3,869
    Prattville, Alabama
    Why? :shrug:
    The stock 3.55's are fine unless you're a dedicated drag racer, then you'd want a set of 3.90's so you could finish the 1320 at middle/top of 4th.
    U.M.
  3. Apophis New Member
    Mar 7, 2004
    Message Count:
    23
    I am getting ready to install 4.10s in my 01 cobra but thats because I am n.a. if I was blown I would stay with the 3.55s The gears will run you around 150.00 plus install kit and oils and if you pay for the install locally they want 388.00.I plan on doing the install myself and I can tell you it has to be perfect.you have a runnout of no more than .003 on the ring gear and the backlash is between .008 and .013 along with the wear pattern meshing right!if it is not perfect you will lock it up or it will whine and wear quickly.This will be my first try and I am a mechanic/tech and it makes me a little nervous.also you must fix you speed with either a chip,tuner,or speed-cal.You could take that 600.00 plus and use it for better performance mods since you already have a supercharger....did'nt mean to blab just my opinion
  4. 99CobraJMS Founding Member
    Sep 10, 2001
    Message Count:
    1,572
    Austin
    I had 4.10s when NA, and then with my current blown power I had to dropped back down to 3.73s, the 4.10s were a mother to launch with.
    I agree, keep the 3.55s.
  5. chrisbudl1 New Member
    Dec 22, 2003
    Message Count:
    444
    springfield MO
    I love my 4:10's. If I had a six speed, I would probably go higher, but that is just me. I didn't buy this car to sit behind old people who won't even go the speed limit. But your car is a little different than mine. to say the least. With my 5 speed, I constantly look for the missing sixth gear when around 75 mph and up. and I still get 220 miles out of a 3\4 of tank of gas, mainly due to traffic and my heavy foot. good luck
  6. SicStang89 New Member
    Mar 15, 2003
    Message Count:
    58
    NJ
    4 10s did me fine but when i put my twin turbos on i will prob go lower like 3 73s.. we'll see.....
  7. 64Comet Member
    Sep 7, 2004
    Message Count:
    30
    Stuck in Lemoore CA.
    I would go with 3.73 if you are going to change them. But just my thoughts.
  8. alfman9 New Member
    Apr 9, 2004
    Message Count:
    219
    Florida
    With the torque you have you dont need lower gears, spend the dough on something for more power!!!
  9. chuckstang95 Member
    Nov 2, 2004
    Message Count:
    138
    Boston
    373's for your car...410's wont help you. I say spend the money else where
  10. greenham64 New Member
    May 6, 2004
    Message Count:
    32
    Keep the gears and buy a pulley, and an diablo tuner. Cya stockness.
Share This Page
