rebuilding a t-5
Discussion in 'Fox 5.0 Mustang Tech' started by tannerc91gt, Nov 5, 2009.
  1. tannerc91gt Advanced Member
    Mar 29, 2009
    Message Count:
    3,933
    18
    68
    Indiana
    so 3rd gear bit the dust the other day. which is fine because the cars coming apart soon and winters coming so no big deal really.
    just curious which way to go in terms of rebuilding it. im not real interested in a stock rebuild because IMO t-5s suck and id just have to do it again down the road
    any one have suggestions or ideas?
    and if its too expensive id be better off picking up a different trans whats a good one to go with?
    also, whats needed to use a t56?
  2. 2000xp8 Advanced Member
    Aug 9, 2003
    Message Count:
    4,620
    68
    NJ
    You only have a few options.
    rebuild upgrades:
    gforce t5
    Astro performance T5
    Completely new transmissions:
    Tremec tko 500 or 6000
    T56
    All of which are going to cost you about 2500 to get setup, except the t56 according to D&D performances site, you are looking at 4 grand to setup a t56.
    Sponsored Ad
  3. 54deuce Member
    Jun 1, 2009
    Message Count:
    104
    It all depends on what you are doing. Any way you go you will spend money on this. The only cheaper route is to rebuild what you have but thats not all that cheap to do plus like you said it will only last so long before it happens again you will spend more money in the long run then getting what you want the first time.
  4. blackened88lx Active Member
    Aug 10, 2006
    Message Count:
    456
    15
    28
    Connecticut
    The astro or g-force gear sets will be around $1200. Plus a clutch and other miscellanious things. It cost me $1600 total to do the Astro gearset in mine with the clutch and everything needed, rebuilding it myself. Yea, it's a lot of money to spend on a t5 but it's been putting up with a lot of abuse for over 10k miles now, and it shifts like butter. We'll really put it to the test next season.
    You could do one of the heavier duty t5 gearsets that are rated at 330ft lbs. I believe they can be found for a couple hundred bucks on ebay. Do a 26 spline input shaft while you're at it and a steel bearing retainer. Rebuild it yourself and you'll be under $1k all said and done and it should be pretty rugged.
    A lot of people consider T5s garbage but I've seen rebuilt ones take some beating. Nothing is lighter, and no syncro tranny shifts smoother. Syncroed tremecs are dificult to powershift, especially in higher rpm.
  5. 2000xp8 Advanced Member
    Aug 9, 2003
    Message Count:
    4,620
    68
    NJ
    If you are considering rebuilding a t5 yourself, be 100% sure that you know you can pull it off, if not, you will up with 100's if not thousands of dollars of scrap metal.
    Home trans rebuilding is not for everyone.
  6. tannerc91gt Advanced Member
    Mar 29, 2009
    Message Count:
    3,933
    18
    68
    Indiana
    I'm not planning on doing it myself...transmissions are not my thing. I've got a buddy who will do it though, just looking for a way to get a decent trans, not gonna be making a ton of power(less than 500 on bottle) so I don't need anything wild just something slightly better than a stock t5
  7. NIKwoaC Mustang Master
    Nov 1, 2006
    Message Count:
    6,481
    125
    113
    Fishers, IN
    The trans in my car is an Astro-built T5. Its not their "A5" gearset, but its an upgrade over the stock WC T5s. I believe it is rated for 350hp. After I sent them my broken T5, I think it only cost me 700 bones, but I believe their prices are higher now- this was a few years back.
    Rebuilding a T5 really isn't that hard if you have a good reference (book/video) and the right tools. The most important thing is to remember is a new or rebuilt unit needs a break in period just like rear end gears do. I rebuilt the T5 I had before the Astro unit, went out and started slamming gears as hard as I could without even letting the engine warm up, let alone the transmission wear in. Needless to say 10 minutes later I had an 80lb paper weight.
  8. 90lxcoupe Active Member
    Oct 8, 2003
    Message Count:
    2,909
    48
    I'd say look for a used TKO setup
  9. jrichker StangNet's favorite TOOL
    Mar 10, 2000
    Message Count:
    18,876
    31
    98
    Dublin GA
    A used Tremec 3550 or TKO is your best bet. Put the right GM Syncromesh Black lubricant in them and they shift good and are almost bulletproof. I put over 100,000 miles on a Tremec 3550 and it was a great improvement over the T5 the car originally came with.
Share This Page
