Rust?
Discussion in '2005 - 2009 Specific Tech' started by Fast05, Mar 18, 2007.
  1. Fast05 New Member
    Sep 17, 2005
    Message Count:
    409
    Ok so I've had the car for a little over two years and I still love it with the exception that it's rusting in 3 spots. There is one spot on the roof where the paint is starting to bubble up and there is rust underneath, and it's rusting in two spots behind the GT emblem on the rear deck. I took it to one dealership who said that paint was covered under the standard 3 yr/36000 mile warranty, and I didn't purchase extended warranty and it's far past 36000 miles. I know this should not be happening on a relatively new vehicle so my question is should I try another dealership? A guy at the body shop said paint was covered for 5 years but I have yet to find someone else that can confirm that. And now I'm in the position to trade it in if I want. Right now the rust spots aren't very noticable until pointed out... I don't want a 3 year old rust bucket when it's paid off....thoughts?
  2. Radman New Member
    Feb 5, 2007
    Message Count:
    115
    My 2007 warranty says 5yr unlimited miles for corrosion. Do you still have your original warranty booklet?
  3. red05bullitgt New Member
    Aug 15, 2005
    Message Count:
    852
    From my understanding, paint and corrosion are covered under warranty for 5 years..Therefore I'd follow Radman's suggestion and also check with you're dealer's service manager as well...
  4. Hoboattacker New Member
    Sep 7, 2005
    Message Count:
    550
    Return it to stock and keep the mods. Trade it in for a brand new 07 or 08 model year and call it a day :)
  5. stanmckinney Active Member
    Mar 31, 2005
    Message Count:
    1,159
    38
    Trade it if you want, but it is covered under 5 year corrosion protection. Make the dealer fix it so no one in the future will have a problem.
  6. ShowYa06 New Member
    Jul 3, 2006
    Message Count:
    148
    I would get ahold of a service manager and make them do the repairs, not just a touch up either.
  7. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    i can tell you from experience the dealer will at the most, sand down the rust or maybe spot sandblast, then fill over the rust.
    i worked at a dealer. did a warranty rust repair on a dodge ram. they told me to fabricate a patch panel and weld that in, instead of replacing the boxside. :notnice:
Share This Page
