I'm pretty sure there's supposed ot be some type of insulation under the shifter panel, cuz right now there's heat coming up through there, but i haven't ever seen anything like that on ebay, so where should i look for it??
no there is a rubber boot, then the leather boot. No insulation, it would probably interfere with the shifter. Make sure you cat shield hasnt fallen off, that will cause heat from the cat to rise up in the shifter hole.
i didnt have the rubber boot when i did my swap.. i only had the leather boot. and i had the same problem with heat coming up throgh the hole. I used rubber placemats doubled up and cut to size. they dont interfear with the shifter and no more heat...
