Shock and Strut Removal and Installation
Discussion in 'Fox 5.0 Talk' started by coachpete, Apr 25, 2008.
  1. coachpete New Member
    Apr 16, 2008
    Message Count:
    12
    Good Morning,
    I am going to try to change out all of the springs as awell as the shocks and struts on my 86 GT this weekend. i was wondering if there are any tips, tricks, possible procedures or even pics of this type of repair? Any help is greatly appreciated, I am trying to get my game plane together before I start the project tomorrow.
  2. impulse001 New Member
    Jan 17, 2008
    Message Count:
    98
    New Jersey
    I'd start by taking the wheels off :shrug:
  3. ryan218 In just 10 years, I'll be old enough to drive!!!!
    Dec 29, 2005
    Message Count:
    214
    27
    38
    columbus ohio
    jack it up first :rolleyes:
  4. Sicarius428 Active Member
    Jan 7, 2004
    Message Count:
    2,079
    46
    Front-Jack the car up and support it by the frame. Take the wheel off and place the jack under the A arm and jack it up to compress the spring. Undo the strut and maybe secure the spring to the car with a chain or something. You may have to undo your steering from the spindle and slowly lower the A arm. DO NOT stand in front of the wheel well just incase it decides to let loose. Ideally you would have a spring compressor but this way works pretty well. Yank the spring out and reverse to install. Also be sure to put the pigtail(bottom of the spring) is in the same way it came out.
    Rear- Jack up the car and support it by the frame. Let the axle hang and remove the shocks. You should be able to just yank the spring out at this point. The rubber insulator between the spring and lower control arm might get eaten so you may want to get some new ones. Also be sure to take note the position of the pigtail is.
    Kevin
  5. MAC'n89Blckstng Active Member
    Jun 11, 2003
    Message Count:
    1,044
    36
    NJ
    He's just replacing the struts, not the springs. No need to take the spring out for that.
  6. magnj New Member
    May 31, 2007
    Message Count:
    145
    :stick:
  7. GTOreturns Active Member
    Oct 1, 2003
    Message Count:
    1,330
    38
    In the arm pit of America.(NJ)
  8. back2fox New Member
    Oct 7, 2006
    Message Count:
    73
    I just installed new springs and shocks on my '86 last month. I used this method from the site listed below. It seemed very safe without using a spring compressor. It took me all day, but it was well worth it.
    http://www.mustangmotorsport.com/springs.html
Share This Page
