Well I have built a few motors before, but prior to this 393 I'm building, I had never done a stroker before. Anyway, I made the mistake of not assembling everything and checking for clearance issues before I sent the rotating assembly out to get balanced. I had put the crank in the block, and made sure that I didn't have anything hitting there, but tonight when I put the first piston in, I found that the skirt of the piston hit the counterweight. This happens on all but 2 of the pistons, so I had no choice but to grind away some material off the counterweight so that everything would clear. I did this for piston #s 1-4 tonight, and I will do the other 4 tomorrow night. What I am wondering is if the material that I am grinding away will be enough to throw the crank out of balance and cause other problems. Should I send everything out to get rebalanced once the counterweights are ground down, or will it be OK to just assemble everything and run it with the material removed from the crank?
Mike
Mike
