What is the difference between like Brembo slotted and drilled vs Ebay slotted and drilled They both look the same and the price is $100 - $200 more depending on where you shop.
there was a very informative thread about this recently if youu want to search...but what i learned is cheap rotors off ebay use cheap refurbished metal and when they are crossdrilled and slotted, that makes them even weaker leading to cracking.
when you say ebay rotors, are you referring to some off brand? if so, why would you even consider going cheap on something like brakes? Go with he best and nothing less IMO
I would just be really weary of ordering something like brakes off of ebay. you really never know what your getting, and theres alot of false advertisement and misleading titles and descriptions
Check out this website. They have some good prices. Not sure on the quality or service though as I haven't ordered anything from them. http://www.speedconcepts.net/Cobra_Bullitt brake conversion kits.htm
i second the powerslot.. like i said before in a previous posting about brakes, my friend with a GSX eclipse purchased slotted and drilled rotors off ebay and they looked like APC plastic when she got them.. not good
Check out crossdrilled connection's site there prices are in between the dirt cheap on ebay and the high dollar brands cant vouch for em but you may want to check em out anyway.
If you're road racing, get only the slotted type. Cross-drilled ones will hurt your braking performance (less surface area for cooling), and will often crack around the holes quickly because of this.
Well honestly i didnt know I was looking at bling factor its just for around town would should i get ?
If just for around town, cross-drilled and/or slotted are fine - you'll have no problems and they'll look good.
i got a set of 99+ Cobra calipers with mounting brackets and brake pads for $160 Shipped . I called ford they wanted $142 a peice Where can i get some cheap ss brake lines from ?
