smog pump and canister removal?
Discussion in 'Fox 5.0 Talk' started by jcw88, Mar 21, 2007.
  1. jcw88 Never played w/ it before so i'm still a virgin!
    Mar 20, 2007
    Message Count:
    53
    fernandina, fl
    i eliminated my smog pump but don't know what i should do w/ the canister? also the valves that are located next to the firewall, i just cut the hoses going to the pump, not what sure if that may cause any harm?
  2. Saleen8786 New Member
    Oct 8, 2003
    Message Count:
    225
    Marlton, NJ
    the canister is very easy to remove,unhook line(make sure to clog it with a bolt cap it off its a vacum line)then slowly pry the canister off with a flat head and its two bolts if i remember that hold the mount in for it. dont know bout the other stuff thou:)
  3. kpack5982 Yeah, it was pretty stiff, but eventually a buddy
    Jul 13, 2005
    Message Count:
    398
    Granger, IA
    That's what I did, just capped the vac lines to the pump. The canister I don't think is a good idea to take out, not sure why, but if memory serves something about gas fumes from the tank being sucked into the intake for better fuel burning?:shrug:
  4. jrichker StangNet's favorite TOOL
    Mar 10, 2000
    Message Count:
    18,896
    31
    98
    Dublin GA
    Why don't people get some education on what things do before raping the car to remove them? Cut or rip out the wrong thing and the car goes into limp mode and you lose power and performance.
    Here's a book that will get you started with how the Ford electronic engine control or "computer" works.
    Ford Fuel Injection & Electronic Engine Control 1988-1993 by Charles Probst :ISBN 0-8376-0301-3.
    It's about $25 from Borders.com see http://www.amazon.com/ . Select boo...and no bad ones, why not hook it up & use it?
  5. iLkYsPoNy if she's a tranny then... well I'd do her.... it..
    Aug 8, 2006
    Message Count:
    125
    Sandusky, Ohio ( Cedar Point - America's Rockin' R
    sheesh.... way to be mean jrichker... all he wanted to do was **** something up... surprised you didn't poke him with a stick and call him a fatty. :rolleyes:
    on a serious note, thats some good advice. :nice:
  6. bloopbloob Member
    Sep 27, 2006
    Message Count:
    630
    Alberta
    First of all, who would sell their beloved stang! thats just crazy talk! 2nd, rip that **** out if you don't have emissions in your state! i took all mine off, and there has been no problems. Mind you, it was for looks and weight not hp.... you won't see much, if any hp gains. Make sure to cap the vac. lines, crossover, and your heads, and u should be fine.Leave the cannister though. it doesn't hurt anything. if u do want to ditch it, get a gas cap that vents, or you could f* up your gas tank!
  7. jcw88 Never played w/ it before so i'm still a virgin!
    Mar 20, 2007
    Message Count:
    53
    fernandina, fl
    thanks it all sounds good , though i think i will just leave it alone...
  8. Busted07 I need my gorilla to be about an inch longer.
    Nov 15, 2005
    Message Count:
    333
    172
    Vapor lock
  9. Flavadave4 Active Member
    Nov 29, 2003
    Message Count:
    1,072
    48
    Utica, NY
    I have ditched my smog, capped the lines but left the canister....so far so good!
Share This Page
