Spark Plug question
Discussion in '2005 - 2009 Specific Tech' started by MATRIX4.6, May 12, 2009.
  1. MATRIX4.6 New Member
    Nov 26, 2005
    Message Count:
    120
    car has 60k and mostly bolt ons and breenspeed/bamachip tunes available via X3. With both tunes 91 octane of course, I get pinging between 4-6k at wot. I haved tried backing out timing but no luck.
  2. MATRIX4.6 New Member
    Nov 26, 2005
    Message Count:
    120
    so my questions are is there another variable to adjust that would eliminate that ping. I have tried going as far as -8 retard for the 4-8k parameter...Or is this a sign that its time for new plugs. By the way this is beyond poor quality fuel and a dirty air filter both systems are cleaned regularly and the car has only tasted Shell or Chevron 91 octane.
    If i do plugs will the HTO have any neg affects on a non blow engine? Thanks in advance for any clarity...
  3. Five Oh Brian New Member
    Jun 14, 2007
    Message Count:
    564
    A colder plug - like the Autolite HT0 or FRPP 3V0 - would be a great idea. The colder heat range will help in your fight against spark knock. The factory platinum plugs may last a long time, but they don't work as well as a good copper plug.
  4. Sogwap55 Member
    Dec 30, 2008
    Message Count:
    59
    I was just logging on to ask about spark plugs as getting ready to swap mine out.
    For a car with basic bolt ons, which plugs would be recommended? Car only has 26k miles but I don't want the dreaded spark plug breakage....
    I was thinking of the Brisk plugs, talked to two local shops and they both recommended them. Is that good? It's about $130 for the set.....
    Any tips or suggestions before changing them? I know to have the car cold.....
  5. CPman New Member
    Apr 3, 2005
    Message Count:
    129
    I'm no tuner, but could be a slightly lean issue and you could try adding a little more fuel at that RPM range to see if the problem gets any better. I would contact your tuner to be sure.
  6. anthony05gt New Member
    Mar 19, 2006
    Message Count:
    1,268
    I agree it could be a lean issue here.
    By the way Brisk plugs are great for race applications, but will not last as long as Autolites.
  7. kenaimone New Member
    Jun 9, 2004
    Message Count:
    82
    here is a good spark removal guide
    C:\Documents and Settings\Owner.YOUR-73CC0455A6\My Documents\mustang stuff\2009-01-02_155622_tsb08-07-06.pdf
Share This Page
