ok guys you asked for it and here it is. i really hope nobody is on dial up!!
engine view
blower reclocked and 45* pipe running down towards the drivers side of the car.
another view lookinh down at the bottom of the engine compartment. the 45* pipe couples to about a 4"straight piece of pipe.
this is the drivers side front of the car. you can see the straight piece of pipe couples to a 90* pipe towrads the front of the car. it then couples to a rubber 90*elbow, then to another 4" srtaight piece of pipe then to the intercooler
this is the passenger side of the IC. i used a 90* piece of pipe here.
the 90* pipe couples to a 90* rubber elbow and up into the engine compartment using a 75* pipe. (note: i cut a hole to run the pipe thru, you may be able to route it a different way but this was the easiest route)
just a view from the bottom of the car.
this is the hole i cut in the inner fender to pass the piping thru. i coupled the 75* pipe to my BPV pipe.
i used a 75* pipe to couple the BPV pipe to the TB.
this is how i connected my mini race back to the intake. dont laugh! it works perfectly!
i hope this helps you guys out. maybe i can convince a mod to let me put all the info together and make a sticky in the tech section!
