T-lok
Discussion in '2005 - 2012 Specific V6 Tech' started by The Fang, Sep 25, 2009.
  1. The Fang Member
    Sep 11, 2005
    Message Count:
    619
    Has anyone installed T-lok in the rear end of the s197 v6? How much and what parts are needed? :)
  2. echo7 Member
    Mar 31, 2005
    Message Count:
    483
    I heard they were very similar (or the same) to the limited slip diffs in Rangers (size wise). Could possibly get one out of a junk yard? I'm not for sure though; was talking with a Ford Mechanic while I was getting some work done.
  3. RNstanger New Member
    May 30, 2004
    Message Count:
    29
    I got mine on ebay new a couple years ago for I think $185. Most places have them for around $200-225. Check ebay first you might get lucky. Plus 2 quarts of royal purple gear oil, 75w140.
  4. V6Vin New Member
    Sep 13, 2009
    Message Count:
    30
    Don't forget to add friction modifier (4-8oz.) to keep the clutches from sticking and to work smoothly. Personally I will be installing a True Trac. No clutches to have to replace. It's a little more $, but I don't like the idea of having to keep going back into the rear end.
  5. V6Vin New Member
    Sep 13, 2009
    Message Count:
    30
  6. DC_Dave New Member
    Oct 6, 2009
    Message Count:
    Yes, I just went through this EXACT decision process myself. I wanted limited slip and steeper gears.
    I looked at swapping gears and/or the carrier and it's a bear. And in the end, I still would have a 7.5" rear end. I looked into eaton truetracs as well, but decided to go with the tried and true trac-loc. My one comment re: wearing out, I hear the carbon clutch pack will go 100k miles, or more. I figure after the first clutch pack goes, I'll just load up the carbons.
    When I looked at how difficult it is to work on the rear end, I ended up buying a 3k 8.8" out of an '07 GT for $350 delivered. I'll be doing the swap and putting in prothane bushings in the next couple of weeks.
  7. The Fang Member
    Sep 11, 2005
    Message Count:
    619
    Good to know guys and thanks for the info. :) Looks like trutrac is twice the price but may be worth the extra.
  8. hmartine New Member
    Aug 20, 2008
    Message Count:
    tlok
    a lot of people have the ford LS. even with SC and NO2 kits. it is a good streetable differential. unless you are planning to go racing every staturday I would not spend the extra cash for others. I'd just add the money to changing gears and all the diff bearings. dont forget the labor charge at about $300.
  9. V6Vin New Member
    Sep 13, 2009
    Message Count:
    30
    Sure, the T-loc works fine. The question is for how long? I know it depends on how you drive it but even if you drive like grandma it will eventually start to slip. Thats what clutches do, they wear. The true trac will not. I plan on driving my car several hundred thousand miles over the next 40 years. I will do this once and be done. :nice: If you aren't putting a lot of miles on you car then the T-loc will be fine, or if you plan on selling it before it needs rebuilt, no problem. :)
  10. BrownPSU78 Member
    Sep 9, 2004
    Message Count:
    119
    is the lsd that ford performance sells any good?
    does anyone have it?
  11. Ken04 New Member
    May 24, 2007
    Message Count:
    246
    everyone with a GT has it. The T-Loc is the standard LS differential. It is a good unit, time tested. It does have to be rebuilt occasionally depending on use but so do alot of friction parts ie; brakes, clutch, fan belts, tires, etc. For the price it's a good buy, you can rebuild it a few times before you surpass the cost of something else.
Share This Page
