haven't found any definite numbers yet, but they look very similar to the dart heads, specs as follows:
Material: 355T6 alum alloy
Comb Chambers: 62cc
Intake Valve Dia: 2.05”
Intake Port volume: 210cc
Intake Port Dim: 2.150”x 1.300”
Int Port Location: Stock
Intake Gasket: Fel-Pro# 1262
Exh Valve Dia.: 1.600”
Exh Port volume: 76cc
Exhaust Port Dim: 1.420” x 1.420” w
Exh Port Location: Raised .135” Std & spread bolt patterns
Exhaust Gasket: Fel-Pro#
Flow, Intake: 310cfm @ .700” lift / 28”
Flow, Exhaust: 180cfm @ .700” lift / 28”
Head Bolts: Dart & 351W block 1/2" OD ARP# 154-3603
302 block 1/2"-7/16” stepped washer ARP# 154-3603
Head Studs: Dart & 351W block 1/2" OD ARP# 154-4003
302 block 1/2"-7/16” stepped washer ARP# 154-4005
Manifold: Most with standard port location
Milling: Min. 50cc (.0065” = 1cc) Flat Mill
Pistons: Most 20º aftermarket pistons.
Push Rod length: Should always measure
Push rod Guide Plate: Comp Cam # 4816 (flat)
Retainers: Steel (10º)
Spark Plug: .750” reach, gasketed, Champion C59C / C59YC
Spring Pockets: 1.550” OD (.030” deeper max)
jegs sells the dart heads for $595 ea. Theres something fishy going on.....
