to lean??
JPstealth
34
Nothern NJ
ok, heres my dilemma... my car is a 00 GT with 60k miles. The engine light is reading lean in bank 1 and bank 2 and i cant figure it out. The car also idles erracticly.
it has C&L intake and maf, reichard intake manifold, full exhaust and a few more normal goodies.
so far i have:
cleaned the K&N filter, the entire intake, and MAF.
I have also checked for vacuum leaks and found a couple small ones which i fixed.
I changed the IAC
put injector cleaner through it
car seems to run fine when driving but i did notice a slight whining in the back of the car at idle, could this be the fuel pump going bad? would that contribute to a poor idle though?
any other suggestions? :shrug:
When did you start throwing codes? Have you had a tune since you added the C&L intake, MAF and K&N combination? I was throwing codes when I went to that set up. I didn't want to get a tune so I replaced the C&L MAF and K&N with the stock MAF and Filter/housing with the rubber nose pulled off and then no more codes being thrown.
I have the same C and L intake and I also have an aftermarket tb and upper plentum and I have o/r exhaust when I took it to get it tuned it was over 25% lean on startup. I was throwing codes just like you wondering wtf. I had a hand held tuner and still was lean. I got a tune and now I'm fine! either get a tune or put the stock stuff back on.
I hate to admit this... but it may help you;
I was having a similar problem with my 2003 GT, I also just turned over 60,000. I have a MAC 85mm Cold Air Intake system and when I put it on my engine started throwing lean codes in both banks and had difficulty starting. I cleaned out my sensors checked the vacuum hoses and had a diagnostic run and it still didn't fix the problem. I put the stock box back on and my codes went away. After a few weeks it crossed my mind that it had been some time since I had the fuel filter changed. (supposed to do it every 12,000 miles) I took it to the shop the following day and had it replaced put my CAI back on and have been running almost a week with no problems and a lot better power!
