Tokico D-Specs strut installation
Discussion in '2005 - 2009 Specific Tech' started by fartingchicken, Oct 14, 2007.
  1. fartingchicken New Member
    Sep 11, 2007
    Message Count:
    45
  2. Casey4s New Member
    Sep 2, 2007
    Message Count:
    236
    You do not need that piece of equipment and most people and small shops don't have one like that either, all you need is one like this.
    [IMG]
    EDIT: You would have one compressor on either side of the spring, NOT like the small picture...
    The one I have is not as nice as this one, I got mine from Harbor Freight for cheap. I have had my spring towers apart three times with these compressors and no problems.
    BUT ! Working with the compressed springs can be dangerous, if you are uncomfortable with attempting this, then you should just have it done for you.
    Good luck with the D Specs, that is what I am considering for myself, let me know how they work out for you.
  3. fartingchicken New Member
    Sep 11, 2007
    Message Count:
    45
    I appreciate all the help you folks have given.
  4. DarkFireGT Playing with my wife's really makes me want one.
    May 23, 2004
    Message Count:
    2,640
    56
  5. SpartaPerformance StangNet Sponsor
    Nov 5, 2006
    Message Count:
    1,682
    38
    UM...if you've never done a MacPherson type strut/shock before DO NOT!!! use those little spring clamps :nono: , if you put them on wrong or compress the spring unevenly you'll take your head off. Take the whole unit out of the car and take it someplace to swap the struts out of the assembly. :nice:
  6. kooldawg6 mine works really well and can take a fair amount
    Aug 31, 2006
    Message Count:
    1,718
    If you're unsure or hesitant of doing it yourself, it is much better to pay somebody to do it for you rather than pay the hospital to fix you back up! I've done the older style twice, but yet have done the MacPherson style. I feel confident I could.
    The rear is easy as you just need to jack up the rear axle to compress the springs, remove the nuts and SLOWLY let the jack down and the springs will just fallout. Having jack stands to have the axle rest on just below the point of spring fallout is a plus. The front is a different animal!
  7. fartingchicken New Member
    Sep 11, 2007
    Message Count:
    45
  8. garbledwords Member
    Aug 29, 2007
    Message Count:
    45
    most auto parts stores will loan you the spring compressors.
  9. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    follow the links on my sig for some good write ups on the situation. very easy swap. if you dont want to do the spring swap, at least remove the strut assembly and take it to the mechanic. they will swap it for cheap. most of the labor cost is in the R&I of the strut. the spring swap only takes a few minutes after the strut is out of the car.
  10. jojomustang New Member
    Nov 21, 2006
    Message Count:
    I just installed some D-Specs last weekend along with some MM C/C plates and some Eibach Pro-kit springs. The front springs were pretty easy with a spring compressor I rented from Autozone, but we just took our time and did a little on each side until they were compressed enough.
    One problem I have now is that the struts extend too far above the strut tower. I can't ge the hood to latch with out the top of the strut touching the hood. I assembled the spacers as recommended in the instructions (one tapered below with one tapered and both the short and tall spacers on top), but I think I may have to disassemble the front again to move one spacer below the CC plate. Anyone have experience with this?
  11. Emay New Member
    Oct 4, 2006
    Message Count:
    233
    The take your head off statement is a little over kill considering these springs are not under nearly enough pressure to do significant damage. This is the most common modification people come to me with in assistance and everytime they just about crap themselves about how easy it is and how safe it can be done with minimal effort and "without" a spring compressor. It's a 30 minute job, nothing more..
    Before anyone gets all fired up about the spring shooting out and hurting you. This video shows it's impossible for that to happen. Too much of the spring is inside the strut tower for it to angle out in any way. Also, it's over the strut assembly until you release it entirely from the tower at which point there is no pressure and the 4 threaded studs at on the top of the assembly are still in their holes on the strut tower. Here you go:
    http://www.v8tvshow.com/forum/index.php?topic=86.msg194#msg194
  12. jojomustang New Member
    Nov 21, 2006
    Message Count:
    Can anyone out there confirm the strut spacer configuration they used installing the Tokico D-specs with the Eibach Pro-kit springs?
Share This Page
