too slow
Discussion in 'SN95 4.6 Talk' started by hskrs10, Oct 1, 2009.
  1. hskrs10 Member
    Dec 21, 2004
    Message Count:
    36
    Nebraska
    I need some help, My friend has a 2000 GT and I have a 98GT. For some reason I cant understand why? When we run them I can get a jump on him then he ends up pulling on me, not alot but more then i would think.
    MY mods,
    2002GT engine swap
    373 gears
    diablo programmer
    offroad x pipe, flowmasters
    70mm throttle body
    upper plenum
    mac cai
    short throw shifter
    His Mods,
    stock motor
    373 gears
    superchips programmer
    70mm throttle body
    k&n CAI
    Any ideas? I'm tired of his mouth!
  2. Kilgore Trout Fried or Broiled ?
    Mar 31, 2005
    Message Count:
    8,317
    76
    Fort Wayne, IN
    There will always be someone faster.
  3. Kornnut Founding Member
    Nov 25, 2000
    Message Count:
    2,056
    58
    DFW
    Do you weigh more then him? Weight in the cars maybe.
  4. hskrs10 Member
    Dec 21, 2004
    Message Count:
    36
    Nebraska
    Yeah, I got a sub box and I'm about 30lb heaver then him
  5. stangtrooper97 Founding Member
    Aug 30, 2002
    Message Count:
    339
    King of Prussia
    You have the same mods except for the shifter. The extra weight is hurting you probably just enough to give him the edge. The only other differences could be he has a better tune. Could also be because 99-2000 GTs have slightly different engines than 01-04s. They were the same spec wise, but the slight differences might make just enough difference. FYI, my 2000 was always a little faster than my friends PI GTs mod for mod, and I'm a big guy at 6'2" and around 240lbs.
  6. Stangdriver13 New Member
    Jul 31, 2006
    Message Count:
    47
    I had the same problem well kinda of, I had my 00 gt against an 01 gt convertible, I had catback, xpipe intake tune, he had full exhaust, intake. I would kill him off the line but he would barely pull up top. I also had heavy cobra rims which I know made a difference.
  7. Tim2002GT Founding Member
    Apr 10, 2002
    Message Count:
    839
    28
    Tulsa, Oklahoma
    30lbs won't make that much difference. Shift points would be my guess as to why he pulls on you. If your not shifting at the proper rpm you can lose some momentum and that could be enough for him to pull ahead. Like stated above, he may be making slightly more power than you due to the tunes you guys have.
  8. squeak93 Active Member
    Jun 2, 2005
    Message Count:
    1,103
    36
    Joplin, Missouri
    +1 on a driver mod. A sn is a bit lighter than a new edge. The 98 also has a pretty good factory tune (even in npi form). My pi engine swapped gt out ran most full bolt on cars, but as stated above, some cars are just freaks and run good.
Share This Page
