Will the driveshaft have to come out? It seems if the output shaft was turning with the wheels it would burn up the roller bearings between the gears and the mainshaft because I thought they rely on the turning of the input shaft (engine) to lube everything, since its the input shaft that turns the countershaft in the sump to spash lube on the mainshaft.
