Tremec 3550 or t5?
Discussion in 'Classic Mustangs' started by jusinbailey, Dec 19, 2003.
  1. jusinbailey New Member
    Nov 9, 2003
    Message Count:
    23
    both 5 speeds have about the same gear ratios from what I have found. The new tremec is about $1400 and is rated at 525 ft/lbs, the t5 at 300 ft/lbs.
    what would be the advantage of the t5? price?
  2. RaSMG Founding Member
    Oct 6, 2002
    Message Count:
    272
    the 3550's are 'stronger' than a stock t5, but the 3550 is only rated at 350 ft lbs not 525. the 3550's retail at 1400 but you can find them for cheaper here
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33733&item=2448606265
    also, the t5's usually have a taller 2.97 first gear versus the steep 3.27 of the tremecs .. a new world class t5 or t5z would run just about the same as that sale price on the 3550 so the 3550 is the better deal. if you need a tranny for more power, tremec also makes the TKO which is rated ar 425 and the TKO II which is rated at 475.
  3. 66P51GT New Member
    Nov 7, 2003
    Message Count:
    721
  4. jusinbailey New Member
    Nov 9, 2003
    Message Count:
    23
    yea, i read that on the same site. whas involved in raising the tunnel?
    also, what first gear ratio would you consider a better gear to use with a 400hp engine on street tires (245's). currently having 3.73 gears. what final gear ratio wouild be ideal?
  5. 66P51GT New Member
    Nov 7, 2003
    Message Count:
    721
    At a guess...
    Stripping the interior
    Cutting the tunnel at the base above the tranny.
    Welding a 1" spacer along the base of the tunnel.
    Re-installing the interior
    Not sure if the standard carpeting can be used.
  6. ddonaca351 Active Member
    Dec 1, 2002
    Message Count:
    2,072
    46
    My 3550 came with the 2.95 first gear in it. The stock (early) t5 has a 3.27, the world class or t5-z has a 2.95. The only mod I had to do when switching from the t5 to the 3550 was move the trans cross member back 1". I just cut the tack welds on the slide tube at the edges of the crossmember and slid it as far back as possible, this allowed *just* enough clearance. (then re-welded it) If you go with the 3550, it uses the t5 yoke, if you go tremec TKO it uses a c6 yoke. (just fyi)
    Oh and Will runs a TKO behind his 45xhp 53xtq @ the wheels turbo cobra and it lived all season on slicks without so much as a whimper... so the ratings they use are probably a little conservative.
    Dave-
    :flag:
  7. 3spd on floor Founding Member
    Aug 13, 2002
    Message Count:
    1,102
    it is not NECESSARY to raise the tunnel to accomadate the 3550, 2bav8, and at least one other i know of that have put in the 3550/TKO with no tunnel mods. In my case, i couldnt afford the 3550, so i have a used (hopefully usable) T5 about to go in, and if/when i blow it up i plan to upgrade it to the Gforce gearset.
    the 'early' (read 'stock 85-93 5.0L') t5's have a 3.35 first gear ratio, not 3.27 which is an optional gearset in the 3550. I dont think 3.27 came in any T5. The heavy duty T5, or T5z has the 2.95 first gear, which is a stronger gearset. The world class T5 is different than the T5z, and came in all 5spd 5.0L mustangs since 1984? I believe the world class is a roller bearing unit, and the NWC is not. i think only 4cyl cars have recieved the NWC unit since 1984 or 1985.
    85-89 5.0L T5's are rated at 260 ft*lbs
    90-93 5.0L T5's are rated at 305 ft*lbs
    http://www.fordmuscle.com/archives/2000/09/t5swap/index2.shtml
  8. SnakeStang65 Founding Member
    Jan 11, 2002
    Message Count:
    160
    I have been saying that you need to raise the tunnel for about 2 years now. Here is a link to my site where you can see what I did to raise mine. Tremec Install It really is not hard, just takes some time.
    You can install the transmission without raising the tunnel, but why go to all that work on your car and then do something so half a$$ed (official engineering term) as that. But as it has been said several times in this forum before, it is your car, do what makes you happy.
    The ideal (best all around acceleration and use of torque) first gear total ratio is about 10:1. With 3.73 final and a 3.27 first that will give you around 12.2:1 which you will find that you will be in second gear before going under the stop light during normal driving. You will have a difficult time keeping your 245's from shredding under hard acceleration. But it will still be manageable. I would not recommend the 3.27 first in you car with 4.11's (13.4:1). With the 2.95 first gear that will put you at 11:1 which you find quite reasonable for daily driving and then you can still swap to 4.11's later to get a 12.1:1 final for when you want to go to the track. Honestly it is up to your own driving preferences, I have found that first gear becomes mostly useless once you cross the 13:1 mark.
    Just my $0.02...
    John
  9. dolfan87 Founding Member
    Dec 29, 2000
    Message Count:
    1,243
    Isn't it just the 65-66 cars that have clearance issues?
    What year is his car?
  10. John Z Founding Member
    Sep 22, 2000
    Message Count:
    581
    Very nice reply - it's great when posts are supported with numbers. I have noticed that my t5 with 3.55 rear gears does not take long to get up to 6000 rpm. Nice job on the of the transmission install.
  11. 302 coupe Founding Member
    Mar 2, 2000
    Message Count:
    1,996
    I have the 3.35 1st gear T5, with a 3.70 rear, that thing is a stump puller! 2nd gear is incredible though......
  12. 302 coupe Founding Member
    Mar 2, 2000
    Message Count:
    1,996
    I will assume you are talking about the 90LX listed in your sig and not a early model. If you are talking about a early model, what kind of crossmember are you using? Tremec's normally won't fit without modifying the tunnel because they are so much wider at the top of the case. If you don't raise the tunnel, the tranny must be angled down so much that it causes driveline angle problems.
  13. coolblue65 Founding Member
    Jul 26, 1999
    Message Count:
    1,211
    36
    I disagree, I have made no mods to my trans tunnel and my Tremec 3550 fits fine, and I do not have any driveline angle issues. I used my stock '65 bellhousing, and installed the trans with a shortened input shaft (from Dark Horse) -instead of the widely excepted use of a spacer plate or late-model bellhousing. And I used the tubular crossmember from Dark Horse. Also was able to use my stock driveshaft.
    I have a 3.50 ring and pinion, so my first gear total ratio = 11.445, and fifth gear total ratio= 2.414. I am really happy with this combo, I really like my shift timing when I shift at 6k. And with the Overdrive I can actually talk (not yell) to someone at highway speeds!
  14. dodgestang Active Member
    Dec 15, 2003
    Message Count:
    1,352
    36
    Yes you are correct you 'can' put the 3550 without mods, but what it involves is using a tranny x member that holds the tail shaft down lower than it really should sit would puts the tranny at a slightly angle, it fits, it works, it runs, but it also becomes the powest point on your car..or so I have heard ;)
    You know....if you're gonna mod the tunnel...there's always that richmond 6 speed out there...something sexy about a mustang with a theroical top speed of a 160-180mph...off course since the mustang is about as aerodynamic as a brick, it might get a little dicey about 130 :nice:
  15. 2bav8 Founding Member
    Nov 30, 1998
    Message Count:
    2,531
    My TKO seems to fit and work just fine for the last 5+ years would out any tranny mods. However, I have managed to go through a clutch, two sets of traction bars and two set of tires.
Share This Page
