Tsb's
Discussion in '2005 - 2009 Specific Tech' started by afixer, Jul 2, 2005.
  1. afixer The Informant
    Apr 3, 2005
    Message Count:
    384
    I have CRS so i cant remember if I posted these. I have all of them in pdf format and have posted most of them at one time or another. if they start a tsb area I can email them all to the moderator. I check oasis weekly, anyone need one just ask
    c ya Tom
    Checked Oasis 5-30-05
    Technical Service Bulletins
    2005 MUSTANG - US (English)
    05-14-4 ( NEW)
    • WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
    05-10-19 (UPDATE)
    • INTERMITTENT CD PLAYER CONCERNS - AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS
    05-9-18
    • DISCHARGED BATTERY - CHARGING SERVICE TIPS
    05-9-14
    • CONVERTIBLE TOP RAISE/LOWER INSTRUCTIONS
    05-9-11
    • FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005
    05-9-3
    • INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
    05-8-8
    • GROWL/GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION - TR3650 MANUAL TRANSMISSION - VEHICLES BUILT BEFORE 1/15/2005
    05-8-6
    • EXHAUST VIBRATION AT 850 RPM - 4.0L ENGINE AND AUTOMATIC TRANSMISSION
    05-7-3
    • AXLE WHINE - VEHICLES BUILT THROUGH 11/15/2004
    05-6-15
    • AIR BAG WARNING LAMP ON - DTC B1891 IN RESTRAINTS CONTROL MODULE OR LAMP FLASHES CODE 53 - VEHICLES BUILT BEFORE 10/02/2004
    05-4-8 (also have them order TANK PROTECTOR) due to breakage at removal
    • FUEL FILL SLOW, OR DIFFICULT TO FILL
    05-3-1
    • MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
    04-26-22
    • MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTIC TROUBLE CODES (DTCS) P035X AND NO DRIVEABILITY SYMPTOMS - 4.6L 3V ENGINE
    04-26-16
    • WELD BONDING PROCEDURE
    04-24-20
    • LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS
    04-24-14
    • GENERAL PCM PROGRAMMING PROCEDURES
    04-24-5
    • REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR
    04-16-1
    • ENGINE MISFIRE OR ROUGH RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS
    04-14-7
    • SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
    04-9-6
    • BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
    ________________
    TSBs found:20
  2. gp001 Founding Member
    Jun 30, 2001
    Message Count:
    4,444
    66
    So. Cal.
    Tom,
    Feel free to e-mail the pdf files to me and I will post them in a sticky post at the top of the forum until I can talk to Tyler to see if we can get a TSB/Known issues section going
    I will PM you with my direct e-mail address
    Thank you for the gracious offer
  3. afixer The Informant
    Apr 3, 2005
    Message Count:
    384
    done check your email
Share This Page
