I have CRS so i cant remember if I posted these. I have all of them in pdf format and have posted most of them at one time or another. if they start a tsb area I can email them all to the moderator. I check oasis weekly, anyone need one just ask
c ya Tom
Checked Oasis 5-30-05
Technical Service Bulletins
2005 MUSTANG - US (English)
05-14-4 ( NEW)
• WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
05-10-19 (UPDATE)
• INTERMITTENT CD PLAYER CONCERNS - AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS
05-9-18
• DISCHARGED BATTERY - CHARGING SERVICE TIPS
05-9-14
• CONVERTIBLE TOP RAISE/LOWER INSTRUCTIONS
05-9-11
• FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005
05-9-3
• INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
05-8-8
• GROWL/GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION - TR3650 MANUAL TRANSMISSION - VEHICLES BUILT BEFORE 1/15/2005
05-8-6
• EXHAUST VIBRATION AT 850 RPM - 4.0L ENGINE AND AUTOMATIC TRANSMISSION
05-7-3
• AXLE WHINE - VEHICLES BUILT THROUGH 11/15/2004
05-6-15
• AIR BAG WARNING LAMP ON - DTC B1891 IN RESTRAINTS CONTROL MODULE OR LAMP FLASHES CODE 53 - VEHICLES BUILT BEFORE 10/02/2004
05-4-8 (also have them order TANK PROTECTOR) due to breakage at removal
• FUEL FILL SLOW, OR DIFFICULT TO FILL
05-3-1
• MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
04-26-22
• MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTIC TROUBLE CODES (DTCS) P035X AND NO DRIVEABILITY SYMPTOMS - 4.6L 3V ENGINE
04-26-16
• WELD BONDING PROCEDURE
04-24-20
• LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS
04-24-14
• GENERAL PCM PROGRAMMING PROCEDURES
04-24-5
• REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR
04-16-1
• ENGINE MISFIRE OR ROUGH RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS
04-14-7
• SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
04-9-6
• BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
________________
TSBs found:20
c ya Tom
05-14-4 ( NEW)
05-10-19 (UPDATE)
05-9-18
05-9-14
05-9-11
05-9-3
05-8-8
05-8-6
05-7-3
05-6-15
05-3-1
04-26-22
04-26-16
04-24-20
04-24-14
04-24-5
04-16-1
04-14-7
04-9-6
________________
TSBs found:20
