Tweecer vs. Tweecer R/T
Discussion in '94-95 Tech' started by CivicEater, Dec 5, 2004.
  1. CivicEater New Member
    Jan 29, 2004
    Message Count:
    585
    What are the main advantages of the R/T? Is it worth the extra 200? Just looking to basic tune and adjust for bigger injectors....
  2. GTJake Founding Member
    Oct 29, 2002
    Message Count:
    3,055
    Ann Arbor, MI
    R/T gives you the ability to datalog. You can get more in depth with your tune this way. A chip may be a cheaper option for you if you're just looking for a basic tune and adjust for the injectors.
    Jake
  3. BlueOvalStangGT New Member
    Oct 28, 2003
    Message Count:
    2,950
    Tampa Florida....USF!!!
    What is needed to tune a car, just a tweecer and a laptop? Or do I need to buy time on a dyno for a/f?
  4. WhiteStallionGT New Member
    Aug 19, 2004
    Message Count:
    481
    Northern VA / VT
    My friend said a chip can increase our hp by 25%. I didn't believe him. A chip won't help a car with very minor mods right?
  5. final5-0 Mustang Master
    Apr 7, 2003
    Message Count:
    6,808
    78
    DFW Texas
    If you want to get into self tuning with the Tweecer you need to data log to verify your changes and see what the various sensors are telling the pcm.
    Trying to self tune and not being able to gather data would be like going to the strip but not being able to know 60', et, mhp, and the like.
    Later
    Grady
  6. 94GTLaserRC Squint as you approach, lest you be blinded by my
    May 7, 2002
    Message Count:
    11,160
    78
    Ernan Says "here it comes... dushbag"
    I thought I wasnt gonna use the Data logging, so I 'almost' got the base model...Im so glad I didnt..
    You need a Dyno with A/F readings for WOT tuning, but you can just use the Laptop and datalog for tuning issues related to driveability.
    I dont know anyone that got the regular over the R/T
    GL...RC
  7. Joes95GT New Member
    Jan 23, 2003
    Message Count:
    3,153
    Delaware
    If you know what you are doing, or have the time to read about it, having the R/T model is like going to a knife fight with a gun....
    Seriously. :D
    Joe
  8. Rootus Officially Addicted
    Feb 8, 2003
    Message Count:
    6,747
    Portland, Oregon
    R/T all the way. IMO it would be painful to try and tune with no feedback. Everything would be a shot in the dark.
    Seriously. :D
    Dave
  9. DFG 5OH New Member
    Aug 28, 2004
    Message Count:
    1,349
    Kentucky
    Joe, do you like Norma Jean?
  10. BlueOvalStangGT New Member
    Oct 28, 2003
    Message Count:
    2,950
    How much does the R/T go for new? Can I use any laptop that has a usb port?($200 from ebay?)
  11. Soupy New Member
    Nov 23, 2004
    Message Count:
    76
    Rhode Island
    So, are you saying that A/F can't be tuned through the RMP range or at WOT. What success or shortcomings have you noticed. Thanks
  12. Joes95GT New Member
    Jan 23, 2003
    Message Count:
    3,153
    Delaware
    I've never heard of her. So I'm going to have to say no. :)
    The A/F ratio can't be tuned directly through the Tweecer without the use of a wideband sensor. What you can do is alter your MAF curve which is an air/fuel table, which does have an affect on your A/F ratio (to an affect). You also have fuel tables and spark tables that can be altered at different loads or RPMs.
    I'll leave the Hardcore explainations to Grady and Dave (both whom have posted in this thread) because they not only have the best grasp on this thing, but they are excellent at explaining stuff - something I'm terrible at if you haven't already noticed. :D
    Joe
  13. Rootus Officially Addicted
    Feb 8, 2003
    Message Count:
    6,747
    Portland, Oregon
    The only Norma Jean I can think of is Norma Jeane, aka Marilyn Monroe. :shrug: :D
  14. Joes95GT New Member
    Jan 23, 2003
    Message Count:
    3,153
    Delaware
    LOL. I never knew that wasn't her real name.
    Please don't laugh. Once again, I'm being serious. :D :rlaugh:
    Joe
  15. final5-0 Mustang Master
    Apr 7, 2003
    Message Count:
    6,808
    78
    DFW Texas
    If you are going to self tune you need to be able to gather data and use various programs to crunch the numbers, graph the data, and the like to see the trends in that data. The Tweecer has a playback feature but I rarely use it.
    You can't determine the af ratio under all conditions unless you purchase a wide band and get a 02 bung installed for the wb's 02 sensor. You can have the wb's output sent to the pcm which allows you to see the af ratio in the dataloggs just like the other data such as rpm, pulse width, spark and the like.
    Having a wb is needed for the same reason as the Tweecer with the RT option.
    You don't need either to make adjustments for tuning but without them you don't know where you are starting from and you don't have any way to verify if you are getting closer to your desired results.
    With a wb you can adjust your af ratio without using a dyno but you will have to use the street. IMHO, this method duplicates real conditions such as load and the like much better that a dyno but the down side to it is ...... its not as safe due to the high speeds needed to get the top end of the maf curve correct.
    I don't see the equipment that I've purchased to self tune any differently than the intake, fuel pump, lt's, etc. That equipment is just another go fast part that is needed for me to get to my goal.
    btw .... If you go the chip route the Pro will do the same basic things using similar equipment while your car is on the dyno.
    Hope this helps someone on this subject of tuning. :nice:
    One last thing .... I'm not as serious as Joe & Dave :D
    Later
    Grady
  16. Soupy New Member
    Nov 23, 2004
    Message Count:
    76
    Rhode Island
    Grady, is there a thread on this? I'd like to get some more information from you about what you've been able to accomplish with the RT and broadband, etc...PM me if you wish to discuss this further, Thanks,
  17. final5-0 Mustang Master
    Apr 7, 2003
    Message Count:
    6,808
    78
    DFW Texas
    Well, I've spread around a few tid bits (some would describe it differently I'm sure) of my findings on using the Tweecer in various threads mostly here and a few threads can be found on the Corral as well. You could search with my name and others that come to mind at this moment are Rockin Rick, GT Jake & Rootus aka Hairy Canary.
    Here is the Tweecer site http://www.tweecer.com/
    Here are the Tweecer support forums:
    http://tweecer.oplnk.net/
    http://groups.yahoo.com/group/tweecer
    That ought to be plenty for you to see if you want to take this farther.
    I gave this stuff here cause I thought it might help others as well :D
    PM me after you do a little reasearch and lurk around on those sites some. I'll be glad to help you if I can :nice:
    Later
    Grady
  18. Joes95GT New Member
    Jan 23, 2003
    Message Count:
    3,153
    Delaware
    See, I told you Grady was a good explainer. :D
    Also do a search under my name and check out the threads that I've started. I have 1 or 2 threads with very common and basic information that should be very helpful in getting you started.
    Joe
  19. final5-0 Mustang Master
    Apr 7, 2003
    Message Count:
    6,808
    78
    DFW Texas
    I'm not sure about that explain thang .......... :shrug:
    I am sure about this .......... :D
    NOBODY gets more performance out of a set of Jack Stands than Joe :rlaugh:
    Later
    Grady
  20. Joes95GT New Member
    Jan 23, 2003
    Message Count:
    3,153
    Delaware
    I can't disagree there. :D
    The axles have been ordered and the posi will be soon - then I'll be out pissing off the neighbors again. :D
    (In reference to the thread you made).... At least my smiley faces work! :spot:
    Joe
Share This Page
