Update: Head Swap Complete
Discussion in '2.3L (N/A & Turbo)' started by JamesBaumann, Apr 27, 2005.
  1. JamesBaumann New Member
    Nov 27, 2003
    Message Count:
    625
    So guys, I finally got my car running again tonight with the new cylinder head. Mods include:
    - Ranger Cam & Followers
    - Port & Polish
    - Shaved 0.50"
    I must say, I am very relieved and disappointed at the same time. I am relieved in that the car runs again and now I can sleep again. However, I am a little disappointed in that there was very little power increase. Could this be due to the fact that my exhaust is still stock and restrictive? Or I dont have a proper cold air kit? I would have expected to see atleast a little power increase, but that was not the case. I have a feeling that my ignition timing is way off, which could be something else to check.
    Anyhow, I was just wondering what experiences anyone else has had that did these same mods. Did they seem to increase your power dramatically? Thanks for any input.
  2. bhuff30 Founding Member
    Dec 11, 2001
    Message Count:
    5,753
    78
    definatly check the ignition timing. If you can still get away with it, you might try 12-14*, but of course detonation will be the deciding factor.
    The compression should give you a crisper throttle responce down low, with some extended rpms up top. The porting should give you a fatter and longer power band. But of course, we are talking about the difference between 90hp and maybe 110-120hp so it isn't going to be earth shattering.
  3. stackz Founding Member
    Jun 14, 2001
    Message Count:
    1,322
    assuming an n/a engine??
  4. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Your engine only flows as well as it's weakest link...I'd guess there is something else in your setup that flows less than the head.
  5. tealtiger93 Member
    May 5, 2004
    Message Count:
    694
    How much does it cost for the port/polish and shaving or did you do it yourself?
  6. JamesBaumann New Member
    Nov 27, 2003
    Message Count:
    625
    I ported and polished myself. The shaving didnt cost me much. Maybe $50, and we are talking Canadian Dollars.
  7. JamesBaumann New Member
    Nov 27, 2003
    Message Count:
    625
    I hear your point. I am still using stock, unmodified intakes. That could definitely be it. I have other intakes that are glass beaded and thoroughly polished. I was planning to swap those on when I did the head, but once I got everything apart I felt I had enough on my plate for the time being. I will swap my intakes on a little later. Should I be port matching these intakes? I wasn't going to because somebody on here told me that I would be losing a lot of low end torque. What's your opinion?
    I am also using a stock, unmodified exhaust manifold with no exhaust mods with the exception of one deleted catalytic. That'll also hurt my flow. I've got a ranger header that is waiting to be swapped on. Again, same story, I was going to do it when I did my head, but then I decided to leave it for another day.
    Anyhow, keeping these things in mind, I still expected to see a little more of a power gain from this mod. I guess I'll set the base ignition timing and see if that helps any.
  8. JamesBaumann New Member
    Nov 27, 2003
    Message Count:
    625
    Yes.
  9. tealtiger93 Member
    May 5, 2004
    Message Count:
    694
    How do you port/polish it? Is it worth the port/polish (since it would be free if I did it) without the shaving?
  10. Dan P. Founding Member
    Apr 27, 2002
    Message Count:
    477
    26
    I would say go ahead and put the Ranger header on, you will see that the motor will rev faster and that it will have more power in the upper RPMs. Plus there is a 20lb difference between the stock header and the Ranger, ever little bit helps.
    Dan
  11. mr_woodster New Member
    Jul 28, 2003
    Message Count:
    1,316
    shave some wieght on that ledsled, youll feel the difference, or nitrous ;)
  12. bhuff30 Founding Member
    Dec 11, 2001
    Message Count:
    5,753
    78
    The exhaust is definatly the restriction here. A long tube with a full 2.5" exhaust would be ideal.
  13. tealtiger93 Member
    May 5, 2004
    Message Count:
    694
    I second that notion. :nice:
  14. JamesBaumann New Member
    Nov 27, 2003
    Message Count:
    625
    Like I said, I've already got that Ranger header ready to go on. I was thinking 2.25" exhaust all the way back, but you think 2.5" will be better? I was kinda worried about backpressure.
    So what was the verdict on the intakes? Am I porting them or not?
  15. tealtiger93 Member
    May 5, 2004
    Message Count:
    694
    I have 2.5" and I'm happy with it. I can't say for 2.25 thought.
  16. MustangLXT New Member
    Nov 1, 2004
    Message Count:
    81
    I'm interested in Port and Polish on my Head as well, can anyone give me instructions on this?
  17. tealtiger93 Member
    May 5, 2004
    Message Count:
    694
    I'd like some info concerning this as well.
  18. JamesBaumann New Member
    Nov 27, 2003
    Message Count:
    625
    Look in the tech articles. There is a link there to a how-to site.
  19. tealtiger93 Member
    May 5, 2004
    Message Count:
    694
Share This Page
