Using Sd Ecu (da1) With Maf Car?
Discussion in 'Fox 5.0 Mustang Tech' started by JohnnyK81, Sep 15, 2013.
  1. For testing purposes, is there any problem with using my ols DA1 ecu in a car that is CONVERTED to MAF? I recall adding the 2 pins for the signal on the MAF (the power was powered off relays in my setup I believe), and IIRC, there are some smog electronics that have to be moved around.. But I believe all those are deleted from my car (67 with EFI).
    So if those TAD and what not sensors are removed, is it cool to plug in a DA1 computer
    Thanks!
