v8 t5
Discussion in '2.3L (N/A & Turbo)' started by stykthyn, Apr 2, 2008.
  1. stykthyn Commander of the snuggie cultists
    Jul 6, 2006
    Message Count:
    5,717
    43
    88
    gainesville
    has anyone ever put one in a four banger fox? is it possible?
    I am doing a v8 conversion on my 93 but, it has been put on hold for a little while.I have all the drivetrane parts already and was wondering if I could use the manual from the v8 car as I have an auto right now and I hate it.
  2. 351wcoupe New Member
    Feb 13, 2003
    Message Count:
    1,845
    Manhattan, Kansas
    Its more than possible its easy.
    There are several issues though.
    1. you need all the 2.3 5 speed swap parts EI bellhousing, flywheel, clutch etc.
    2. A slightly differnt input bearing/bushing is needed.
    3. The reason trubo 2.3 guys like the V8 trans is because it doesn't have as low of a first gear. That low first gear helps the N/A cars from being so gutless. All in all you have a slightly stronger car (maybe) and you'll have to swap it all again when you go V8.
    Its WAY easier to leave it alone and just drop in the V8 and trans already bolted together.
  3. stykthyn Commander of the snuggie cultists
    Jul 6, 2006
    Message Count:
    5,717
    43
    88
    gainesville
    not worth the effort then? I was hoping to ditch the slush box, but if the first gear ratio is higher then my car will be even more of a turd. oh well.
    thanks for the info
  4. 351wcoupe New Member
    Feb 13, 2003
    Message Count:
    1,845
    Manhattan, Kansas
    The first gears are close but the T5 still may be lower.
    Its certainly not worth the effort at this time unless you were going to stay with a 2.3. Even then I would swap everything together and deal with the A4ld as long as its alive.
  5. Red_LX Doubt I could be of much help, unless you need por
    Aug 21, 1998
    Message Count:
    10,498
    78
    Morgantown, WV...where couches meet their doom
    Actually the fifth gear would make your car a turd. .6 OD + 2.3L = well, I hope you don't have to go up any hills.
Share This Page
