Vibration Problem
Discussion in 'Fox 5.0 Mustang Tech' started by superdavestrate, Feb 5, 2012.
  1. superdavestrate Member
    Nov 7, 2008
    Message Count:
    32
    south tally fla
    I'm having what feels like an engine vibration at around 2500rpm driving or coasting down the road or just sitting still withe clutch pushed in .As I raise the rpms it comes in very noticable at 2500.I have changed motor and trans mounts and will check balancer one more time,any thoughts?
  2. nibik91 Member
    May 12, 2010
    Message Count:
    51
    does it get worse as speed and rpm increase? what is it like at highway speeds?
    Sponsored Ad
  3. superdavestrate Member
    Nov 7, 2008
    Message Count:
    32
    south tally fla
    It seems to stay as it increases, I think I have another vibration i can feel in the shifter,maybe carrier bearing,axle bearing,or shaft but has worst vibration with clutch pushed in around 2500rpm
  4. 1mustang89lx New Member
    Sep 16, 2011
    Message Count:
    jacksonville,nc
    brother I have the same problem i have had the trans rebuilt and replaced mounts tranny/crossmember and the balancer but still no dice.
  5. rc4mike Member
    Oct 11, 2006
    Message Count:
    142
    I'm having a similar problem. Ran a cylinder balance test and found a dead cylinder. Now I can figure out why it's dead. Everything checks out yet it's still dead. Run that test and check codes.
  6. Noobz347 Stangnet Facilities Maint Tech... Er... Janitor
    Jan 5, 2011
    Message Count:
    10,821
    378
    133
    Box behind Walmart
    Not a digital tuning issue.
    Moved to Tech
Share This Page
