what next?
Discussion in '2005 - 2009 Specific Tech' started by FR-S8N, Jun 2, 2008.
  1. FR-S8N Founding Member
    May 23, 2002
    Message Count:
    1,311
    after ordering the jlt intake w/ sct x3, what should come next. i have about 1k left to spend.
  2. DarkFireGT Playing with my wife's really makes me want one.
    May 23, 2004
    Message Count:
    2,640
    56
    Gears and LCA's should take care of that $1k. Or UDP's, Charge Motion Delete Plates, LCA's, and a shifter.
  3. 05wolfkiller Member
    Sep 5, 2006
    Message Count:
    115
    i would go gears and shifter. good luck:nice:
  4. FR-S8N Founding Member
    May 23, 2002
    Message Count:
    1,311
    i'm thinking about buyingsome 373's. but i have no idea what the factory gear ratio is.
    will it somewhat improve the 1/4 time?
    I already ordered the sct tuner. after the gear install is it difficult to adjust the sct tuner or do i have to send it somewhere for a retune?
  5. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    If you've got 3.55s, I'd save your money unless you go up to 4.10s. The rule of thumb when replacing gears is that if you don't go up at least two gear sizes, it's almost a waste. I agree with it completely.
    Now I'd suggest doing Steeda UDPs and CMCVs. Now you'll need a tune for the CMCVs and I highly suggest Justin at VMP Tuning. It'll be $50 for a single tune file. I usually recommend Justin but I'm highly recommending him for the tuning of CMCVs. I've never seen someone tune for them better than him. No loss of part throttle power, no loss of mileage. I gained power all over the curve. Both of those will net you about ~12 rwhp.
    I'd highly recommending getting a short throw shifter if you don't have one. I'd go with the MGW. I had a lot of buddies who tried to talk me into the Hurst because it was so good or so they thought. I spent the extra money on the MGW. Once you receive it and open the box you'll be completely impressed. Once you go for a drive, you'll be even happier. Once my friends drove my car with the MGW, they said it was hands down better than the Hurst. A few of them even switched to the MGW. Point is, do it right from the beginning. The only downside to the MGW is the price.
    I'd also highly recommend getting the CHE K-Member Brace with Torque Limiters. I got the ones with rod ends and I kind of regret not getting the poly ends. I thought I'd need the rod ends with the way I drive but they do make a lot of noise on bumpy roads. I think I would of been able to get by with the poly ends now. After getting the MGW, I started missing third and couldn't understand why. The shifter was supposed to fix all of that. Well the transmission was under a great amount of deflection so after getting the CHE K Member Brace with TLs the problem was fixed. It's only ~$130 so it's money well spent.
  6. FR-S8N Founding Member
    May 23, 2002
    Message Count:
    1,311
    thanks for all the great advice. i'm looking into the CMCV's. It doesn't appear to be a difficult mod. I just have one question: where do they go?
    I also forgot to mention that my GT is an automatic.:)
    the sct x3 is already in transit. I checked the current status through DHL. If i order the CMCV's i'll have the SCT just sitting here while I wait. I guess its smart for me to send it to get retuned while I wait for the rest of my parts to arrive.
    Is it hard to hooked it up to the vehicle? Are there instructions anywhere?
    The Charge motion plates from steeda are $299. How come at ninosport they are $139?
  7. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    No problem. The CMCVs mount underneath the intake manifold. All you do is remove the intake, pull the injectors, all the wires mounted to the manifold, etc and pull that off. Once that's off you take off the stock charge motion plates with the butterflies and motor. Remove the motor. Take the o rings off of the stock plates and put them in the new ones. After that just do everything in reverse. It comes with instructions so you're going to be alright. The reason why you're seeing two different prices is that you're looking at the billet plates from Steeda, you don't need those. They make a set called the econ plates, those are what you want. They are the same price. Ninosport is probably selling the Steeda ones anyways.
    The tuner just plugs into your ODB-II port underneath the dash by the steering wheel. If you look you'll see a little black plug, it just plugs into that. Tunes can be sent via email. Once you receive them and save them, you use a program called Live Load which can be downloaded on the SCT website and you just load them on the device. It's easy.
  8. FR-S8N Founding Member
    May 23, 2002
    Message Count:
    1,311
    recieving the tunes through email sounds a lot easier than shipping it back and forth. what places do it this way?
    any idea how much labor is for the CMCV's?
    Ninosport are selling the Steeda brand but around 139.99.
    I also decided not to change the ring and pinion. stock is fine for now.
  9. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    Most tuners do it that way unless you don't know your PCM Code. If you don't know it, they send it to you so you can read it and send it back and than send you the tuner loaded with tunes. Once you know your code than you can have tunes emailed, easily. Tunes are only $50 from VMPTuning.com.
    Also don't waste your money paying someone to install the CMCVs. It's only about a hours worth of work. Super easy, only need hand tools. I did mine on the dyno. :lol:
  10. FR-S8N Founding Member
    May 23, 2002
    Message Count:
    1,311
  11. DarkFireGT Playing with my wife's really makes me want one.
    May 23, 2004
    Message Count:
    2,640
    56
    Just make sure you have a torque wrench that works accurately. I cheaped out and bought an Autozone one and snapped 2 manifold bolts putting it back together. luckily, they were in the middle. I haven't gotten around to dealing with trying to get those out of there yet.
  12. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    Yikes. I used hand tools and just followed the diagram. I didn't use a torque wrench on them, worked out fine though.
  13. DarkFireGT Playing with my wife's really makes me want one.
    May 23, 2004
    Message Count:
    2,640
    56
    I wish I had! I always hand tighten everything until I feel is sufficient. But I ready TacoBill's write-up, and he was very specific about torquing (I believe to 33 ft/lbs), so I figured I'd better. Bit mistake. I have a Craftsman Digital now, though. Learned a lesson.
  14. V8JamesGT New Member
    Jan 22, 2006
    Message Count:
    215
    I would go with Lowering Springs (About $225), Shocks/Struts (D-Specs are about $500), an adjustable Panhard Arm Bar (About $130), and last but not least some good Lower Control Arms ($130-$200)
  15. kooldawg6 mine works really well and can take a fair amount
    Aug 31, 2006
    Message Count:
    1,718
    After getting the tune loaded in the car you will notice a huge difference in the way the transmission acts! I was pleasantly shocked! Then you go into the tune and you can increase the shift pressure up to 25% over stock in any gear you want(in 5% increments)and enjoy the neck snapping/tire chirping shifts into 2nd and 3rd depending on tires/gears. Also, turn off the traction control and you can haze the tires at will!
  16. Five Oh Brian New Member
    Jun 14, 2007
    Message Count:
    564
    For our automatic GT's, I highly recommend 4.10 gears and an aftermarket stall converter for the trans. Once your budget allows, forced induction is so very cool.
  17. BudgetPlan1 New Member
    Apr 28, 2008
    Message Count:
    39
    I did the CAI/SCT X-cal thing as well. Next on the list is FRPP 3.73's (I got a 5-speed w/ 3.31's) and MGW shifter. I pondered 4.10's but think I may then get into traction problems and I really don't wanna start getting into the suspension that much to control the traction better. Car is a 2008, a month old w/ 1600 miles and I'm just getting stuff outta the way quick so I can catch up to the vette (12.8@110). I figure (hope) w/ the CAI, tune, 3.73's and shifter I'll be down around 13.3's consistently which will be enough to catch my wife napping at the line in her car on the occasions we race.
Share This Page
